Re: Can't start Eclipse after upgrading (3.1 to 3.1.1) [message #293071 is a reply to message #293041] |
Mon, 17 October 2005 15:52 |
Originally posted by: douglas.pollock.magma.ca
darkangel wrote:
> I recently upgraded Eclipse to version 3.1.1 using the instructions on the
> following page:
> http://www.eclipse.org/eclipse/platform-releng/updatesfor3.1 .1.html
> .. now I can't start Eclipse ...
> java.lang.VerifyError: class org.eclipse.ui.commands.AbstractHandler
> overrides final method .
Judging by this, your install has somehow become messed up. I would
recommend copying your workspace directory (or directories) to a safe
location, and then deleting the install. Download a new Eclipse 3.1.1.
org.eclipse.ui.commands.AbstractHandler hasn't changed since before 3.1.
cheers,
d.
Re: Can't start Eclipse after upgrading (3.1 to 3.1.1) [message #293138 is a reply to message #293126] |
Tue, 18 October 2005 20:15 |
Dodger wrote:
> Is there no other way? Downloading all that again will be painful on my
> dial-up! :P
It's too hard to tell what needs to be done.
> Also, is it normal that I still have 3.1.0 files after the upgrade? Like:
> org.eclipse.ui.workbench_3.1.0.jar AND org.eclipse.ui.ide_3.1.1.jar
It is normal to have 3.1.0 files after the upgrade. Any plug-in that has
not changed will remain as 3.1.0. However, org.eclipse.ui.workbench did
change, so this is *not* normal.
See "https://bugs.eclipse.org/bugs/show_bug.cgi?id=112127" (and others) for
possible reasons.
cheers,
d.
Re: Can't start Eclipse after upgrading (3.1 to 3.1.1) [message #293179 is a reply to message #293144] |
Wed, 19 October 2005 15:58 |
darkangel wrote:
> I get the feeling that that class somehow became corrupt during the
> update process. I think (I really don't know much) it could be fixed by
> replacing that file. Could you maybe send this file to me? I tried
> compiling the java file in CVS, but received two error messages.
Try running with "-clean".
If it still persists, I would recommend downloading Eclipse again. I know
it will take a while on your modem, but there's not much I can do. You
only really need to replace "org.eclipse.core.commands" and
"org.eclipse.ui.workbench" for this particular problem. You might try just
downloading the "Platform Runtime Binary", and extracting the pieces you
need.
d.
FUDForum. Page generated in 0.04775 seconds
