Home » Eclipse Projects » Eclipse Platform » Simple problem,how to get 'Shell' object from plugin's views?
Simple problem,how to get 'Shell' object from plugin's views? [message #291520] Sun, 18 September 2005 11:44 Go to next message
Originally posted by: guru.lifesting.com
I created a class named 'shutdown' extends 'Viewpart' to
be a view of my eclipse plugin,now I want to add an action
which simply open a file-choose box using MessageDialog
class to this view,but the MessageDialog's constructor me-
thod must need a shell object as primary parameter.
So the problem is how to get the 'Shell' from anywhere?
Thanks!
life.sting
Re: Simple problem,how to get 'Shell' object from plugin's views? [message #291521 is a reply to message #291520] Sun, 18 September 2005 14:18 Go to previous messageGo to next message
> Thanks!
> life.sting
you can add null too MessageDialog or get shell like this
PlatformUI.getWorkbench().getDisplay().getActiveShell();
Re: Simple problem,how to get 'Shell' object from plugin's views? [message #291538 is a reply to message #291521] Mon, 19 September 2005 06:59 Go to previous messageGo to next message
Very very thank you!Follow your direction ,I have solved
this problem.
Re: Simple problem,how to get 'Shell' object from plugin's views? [message #291541 is a reply to message #291520] Mon, 19 September 2005 07:53 Go to previous messageGo to next message
If you want to make sure you are using the same shell as your view, you
can go viewpart.getSite().getShell().
Later,
PW
Re: Simple problem,how to get 'Shell' object from plugin's views? [message #291698 is a reply to message #291521] Wed, 21 September 2005 15:21 Go to previous message
Try to use the shell associated with the view not the active shell - it is
potentially different.
Use IViewPart#getSite()#getShell()
Tod Creasey
Eclipse UI Committer
"snpe" <snpe@snpe.co.yu> wrote in message
news:dgk40j$idl$2@news.eclipse.org...
> > Thanks!
> > life.sting
Previous Topic:FontRegistry
Next Topic:[Fwd: Eclipse and ClearCase woes]
Current Time: Sun Oct 26 04:50:55 EDT 2025
Powered by FUDForum. Page generated in 0.05044 seconds
