Re: problems view [message #29062 is a reply to message #29024] |
Mon, 21 July 2008 12:39 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Alex Panchenko![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=alex.panchenko%40gmail.com) Messages: 342 Registered: July 2009 |
Hi Abhijit,
Abhijit wrote:
> I downloaded the latest dltk 1.0 integration build. I created a ruby
> script using ruby IDE, made changes so as to produce syntax errors, the
> error squigglies were shown at correct line numbers. However, the
> problems view was blank; it showed no errors. I then saved the script
> and problems view got refreshed.
That was the changes started on the last week: problems view will
display only errors from parsing the saved content - errors during file
editing are reported only as annotations in the editor. Saved files are
parsed in the background independently from the editor. Now you can use
Project - Clean to force reparsing sources, etc.
> Also i observed one more thing- in the same script, the saved copy had
> syntax errors; so i removed those errors but closed it without saving.
> The next time i opened the ruby script, it opened the previous saved
> copy (which has errors) correctly but now the error squigglies were not
> shown, also the problems view was blank.
> Can you please guide me in this?
That changes are not finished completely. The issue you reported is
fixed today - new build will be uploaded later today. Btw, integration
builds are now posted almost every day.
> Thanks & Regards,
> Abhijit.
Alex
FUDForum. Page generated in 0.03330 seconds
