Multipage XML Editor [message #286332] |
Tue, 07 June 2005 14:14 |
Originally posted by: Langerjo.de.ibm.com
Hi @ all!
Anyone knows a nice tutorial how to create a multi page editor, which
edits an xml File like the plugin.xml?
And which eclipse plugin defines the functionality for editing the
plugin.xml?
Thanks in advance
Johannes
Re: Multipage XML Editor [message #286353 is a reply to message #286332] |
Tue, 07 June 2005 16:34 |
Originally posted by: eclipse.rizzoweb.com
Johannes Langer wrote:
> Hi @ all!
> plugin.xml?
I'm not sure if you're looking for this info as a learning tool or
because you want a good generic XML editor to use. If it is the latter,
you'll find that there are already several good XML editors available
for Eclipse. One is XMLBuddy, MyEclipse includes another one. Also,
search at www.eclipse-plugins.info for more.
HTH,
Eric
Re: Multipage XML Editor [message #286383 is a reply to message #286353] |
Wed, 08 June 2005 09:00 |
Originally posted by: jerome.bourgeon.bull.net
>> Hi @ all!
>> plugin.xml?
> HTH,
> Eric
NB: it's an example (not for doing a XML multi page editor, but a multi
page editor) i don't know if it's a good use but it works( excuse me I'm
a little busy today if you have some question, and if there are mistakes
you can correct me (I'm a newbee).
to create a multi page editor you need :
- in the plugin.xml :
<extension point="org.eclipse.ui.editors">
<editor
class="org.example.XMLEditor"
default="true"
icon="penguin.gif"
id="org.example.XMLEditor"
matchingStrategy="org.example.XMLEditorMatchingStrategy"
name="XMLEditor">
</editor>
</extension>
You can add of course the extension of the files, the icon...
- The class XMLEditor
public class XMLEditor extends FormEditor {
public static final String ID_EDITOR = "org.example.XMLEditor";
//$NON-NLS-1$
protected FormToolkit createToolkit(Display display) {
// Create a toolkit that shares colors between editors.
return new
FormToolkit(ConfigurationPlugin.getDefault().getFormColors(d isplay));
protected void addPages() {
try{ // note book like in the editor
addPage(new FreeFormPage(this));
addPage(new FreeFormPage2(this));
addPage(new FormPage3(this));
addPage(new FormPage4(this));
addPage(new FormPage5(this));
}catch(PartInitException e){
public void doSave(IProgressMonitor monitor) {
// TODO Auto-generated method stub
public void doSaveAs() {
public boolean isSaveAsAllowed() {
return false;
public void init(IEditorSite site, IEditorInput input) throws
PartInitException {
this.setPartName(input.getName());
this.setTitleImage(ConfigurationPlugin.getImageDescriptor("an
image").createImage());
this.setTitleToolTip(input.getName());
super.init(site, input);
- a class XMLEditorInput whiwh define your instance of an editor
public class XMLEditorInput implements IEditorInput {
private String name = null;
public XMLEditorInput() {
super();
// TODO Auto-generated constructor stub
public XMLEditorInput(String name) {
super();
this.name=name;
public boolean exists() {
return true;
public ImageDescriptor getImageDescriptor() {
return null;
public String getName() {
return name;
public IPersistableElement getPersistable() {
return null;
public String getToolTipText() {
return name;
public Object getAdapter(Class adapter) {
return null;
public boolean equals(Object obj) {
if (obj == null) return false;
if (! (obj instanceof XMLEditorInput)) return false;
XMLEditorInput other = (XMLEditorInput)obj;
if (!(other.name.equals(this.name)))return false;
return true;
public int hashCode() {
return name.hashCode();
- the matching strategy class
public class XMLEditorMatchingStrategy implements IEditorMatchingStrategy {
public XMLEditorMatchingStrategy() {
super();
public boolean matches(IEditorReference editorRef, IEditorInput input) {
try { // check you have not the same editoralready open, useful for
opening a new one
return editorRef.getEditorInput().equals(input);
} catch (PartInitException e) {
e.printStackTrace();
return false;
- the pages you add
public class FreeFormPage extends FormPage {...
Here you can do your "editor" for an XML
I you use a tree view you have done by yourself
in the double click action for example do this :
doubleClickAction = new Action() {
public void run() {
ISelection sel = viewer.getSelection();
if (sel instanceof IStructuredSelection) {
IStructuredSelection selection = (StructuredSelection) sel;
Object obj = selection.getFirstElement();
IWorkbenchPage page = ConfigurationPlugin.getDefault()
.getWorkbench().getActiveWorkbenchWindow()
.getActivePage();// it's the plugin.java of my apps
File temp = (File) obj;
try {
IEditorInput input = new XMLEditorInput(temp.getName());
page.openEditor(input,
"The id of your editor");
System.out.println(e);
THE END :D
FUDForum. Page generated in 0.02109 seconds
