JUnit Plugin Test No-Longer runs in M7 [message #285534] |
Wed, 18 May 2005 14:41 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: alfiewong.gmail.com
After migrating from M6 to M7 my JUnit Plugin test no longer run. I get
the following error everytime I run a Plugin test.
org.eclipse.swt.SWTException: Failed to execute runnable
(java.lang.NoClassDefFoundError:
org/eclipse/jdt/internal/junit/runner/RemoteTestRunner)
at org.eclipse.swt.SWT.error(SWT.java:2691)
at org.eclipse.swt.SWT.error(SWT.java:2616)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.j ava:161)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchroniz er.java:25)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:3096)
at
org.eclipse.ui.internal.testing.WorkbenchTestable.runTest(Wo rkbenchTestable.java:83)
at
org.eclipse.pde.internal.junit.runtime.UITestApplication.run Tests(UITestApplication.java:97)
at
org.eclipse.ui.internal.testing.WorkbenchTestable$1.run(Work benchTestable.java:56)
I'm not sure why this occurs but any help would be appreciated. All I did
to migrate over was point M7 to my M6 workspace.
Re: JUnit Plugin Test No-Longer runs in M7 [message #285546 is a reply to message #285534] |
Wed, 18 May 2005 17:13 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: ya_xiang.hotmail.com
junit plugin-test works well.
what you need just is a clean eclipse.
Regards.
xiangya.
"Alfred Wong" <alfiewong@gmail.com> ????
news:ef38c15e6c9b726a8a7544b27d015d9b$1@www.eclipse.org...
> at
java:83)
> at
ication.java:97)
> at
va:56)
Re: JUnit Plugin Test No-Longer runs in M7 [message #286068 is a reply to message #285534] |
Wed, 01 June 2005 18:18 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Did anybody get this working?
Alfred
> at
> at
> at
> at
> did to migrate over was point M7 to my M6 workspace.
FUDForum. Page generated in 0.03585 seconds
