Home » Eclipse Projects » Eclipse Platform » custom build questions.
custom build questions. [message #273015] Wed, 29 September 2004 20:15 Go to next message
I posted this a couple weeks back, but no answer. Repost.
I have two problems with custom build. They are:
(1) I have my build.xml checked into source control for console build.
But when I do an export on the feature in the Eclipse environment, it
fails because it can't overwrite the build.xml. So, I was told to set
custom=true, but still the problem occurs.
(2) How do you make the doc.zip once you have custom build working? I
have a plugin that is a user guide for my other plugin.
Re: custom build questions. [message #273054 is a reply to message #273015] Thu, 30 September 2004 10:55 Go to previous messageGo to next message
(2) Use ant's zip tasks.
AL wrote:
> Thanks
Rich Kulp
Re: custom build questions. [message #273164 is a reply to message #273054] Thu, 30 September 2004 19:31 Go to previous messageGo to next message
Thanks for the tips, but how to do the below step, step (2), that you
suggested.
I right-click on the 'build.xml' file and choose 'Run->External Tools'.
I got all the targets of the build.xml shown, but no target that says
to zip up the html stuff into the doc.zip.
Thanks.
> AL wrote:
>> Hi,
>> Thanks
Re: custom build questions. [message #273197 is a reply to message #273164] Fri, 01 October 2004 10:06 Go to previous message
No, I meant you have to update the build.xml to add the tasks to zip up
the doc. There is no way to tell PDE to do it for you.
Rich Kulp
Previous Topic:How to make a Job show the reason why it is blocked?
Next Topic:Eclipse 3.0 DLL-loading with cyclic dependencies
Current Time: Thu Oct 23 05:58:23 EDT 2025
Powered by FUDForum. Page generated in 0.44375 seconds
