Re: Eclipse won't start [message #269789 is a reply to message #269780] |
Fri, 27 March 2009 14:04 |
Originally posted by: eclipse-news.rizzoweb.com
On 3/26/2009 4:07 PM, Walter Harley wrote:
> "hongsun "<hongsun@gmail.com> wrote in message
> news:27c1ee9fdda3e56d0743e14ff2e92325$1@www.eclipse.org...
>> I install eclipse in a windows xp professional x64 edition pc(I delete the
>> old folder)
>> I have java vm installed in "c:\program
>> files\java\jdk1.6.0_13\jre\bin\javaw.exe"
>> When I run eclipse, it starts a few second then stops. From Windows Task
>> Manager, I can see that eclipse and javaw start and go.
>> What happens? any help?
> What did you use to unzip Eclipse? If you used the Windows built-in unzip
> tool, you may have corrupted files. Try using WinZip or something like
> that. (This is documented on the download page, somewhere...)
> Also, make sure that you are actually using the VM you think you are using.
> Sometimes other applications install old out-of-date JVMs on the path. If
> you open a command shell and type "java -version", what do you get? (You
> can also specify a particular JVM location in your eclipse.ini or on the
> Eclipse command line.)
> You may find some answers at
> http://wiki.eclipse.org/FAQ_I_unzipped_Eclipse%2C_but_it_won %27t_start._Why%3F .
Also, make sure if you are using a 64-bit JVM that you have a 64-bit
build of Eclipse. If you have a 32-bit JVM make sure you are using
32-bit Eclipse (the default).
Eric
Re: Eclipse won't start [message #269954 is a reply to message #269918] |
Fri, 03 April 2009 17:32 |
On 4/2/2009 4:08 PM, Anh wrote:
> Hi everybody,
> I have the same problem with Eclipse start up. I have followed the
> instruction from wiki.eclipse. My system is VirtualBox (host OS is
> WinXP) with centOS 4.6 (linux kernel 2.6), Eclipse 3.1, j2sdk 1.4.2.
> Here are my setting:
> java path is already point to j2sdk1.4.2
> /home/<user_name>/Desktop/j2sdk1.4.2_18
> (not to RedHat.gjc) under non-root account (checked with: $ which java)
> java -version is 1.4.2
> I've modified the eclipse.ini:
> -vm
That needs to point to the Java executable file, not the directory. For
an example, see http://wiki.eclipse.org/Eclipse.ini
> The error ms come when i run eclipse:
> JWM terminated. Exit code = 1
> /usr/bin/java
> -Xms40m
> -Xmx256m
> -vm /home/<username>/Desktop/j2sdk1.4.2_18/bin/java
> -jar /home/<username>/eclipse/startup.jar
> -os linux
> -ws gtk
> -arch x86
> -launcher/home/<username>/eclipse/eclipse
> -name Eclipse
> -showsplash 600
> -exitdata 13000f
> -vm /usr/bin/java
> -vmargs
> -Xms40m
> -Xmx256m
> I've noticed that -Xms40m.....-jar /home.... repeat 2 times, it's like
> eclipse.ini is concatenated with some other setting and there is -vm
> point to the /user/bin/java
> Do you have any idea?
> Thank you
FUDForum. Page generated in 0.10980 seconds
