| Double click in package explorer: toolbar resize: unintended file operations [message #269793] |
Fri, 27 March 2009 22:57  |
Originally posted by: sreed.spamcop.net
I have been plagued by files jumping from folder to folder or being copied
and pasted in the package explorer when I open them to edit by double
clicking. I have a notion about what is happening and wonder if there is a
way to work around this problem.
In most Perspectives, the package explorer sits just under the toolbar.
When a file is selected in the package explorer, the toolbar is usually
one row of icons. If I open a file in an editor that adds items to the
toolbar and causes it to change from one row of icons to two, the package
explorer is shortened and the file that was opened is no longer under the
cursor. Then due to some mouse event hokus-pokus and depending on what
lies under the cursor, the file is dragged and dropped into a neighboring
folder or a copy and paste operation is detected by the package explorer.
I would welcome any advice on how to configure Eclipse to avoid this
behavior.
| Re: Double click in package explorer: toolbar resize: unintended file operations [message #269848 is a reply to message #269834] |
Tue, 31 March 2009 10:31   |
Originally posted by: eclipse-news.rizzoweb.com
On 3/30/2009 8:37 PM, Scott Reed wrote:
> I am mainly experiencing this when using ZK Studio (an Ajax IDE,
> www.zkoss.com). When their "Zul Editor" has focus it adds a few icons to
> the toolbar. This can be enough to cause the toolbar to expand and
> contract as focus enters and leaves the editor. If focus is changed from
> the editor to the package explorer by selecting a file in package
> explorer, it appears that Eclipse interprets what happens as a drag and
> drop operation, either a copy of the selected file if the cursor ends up
> over the same folder, or moving the file if it ends up over an adjacent
> folder. You will be able to see it in the video - I scrunched the window
> down to minimize file size so it starts with 2 rows of icons in the
> toolbar and goes to three when the Zul editor gets focus. See if you can
> download it from http://home.comcast.net/~vvmade/vid/eclipsebug.avi.
That does look quite irritating. Unfortunately, I can not reproduce it
using just Eclipse JEE package (editing JSP files which make the toolbar
larger than normal similar to the Zul editor in your demo). I tried
shrinking the workbench window down just like in your demo, but could
not get any copy-file prompts like you did.
At this point, I'd encourage you to try to reproduce this without the
Zul editor; if you can't, then you should go to the ZX Studio forums and
ask them to look into it.
If you can reproduce with "base" Eclipse, then enter a bug report
(linking to or attaching your screencast would probably help with the
explanation) about it: https://bugs.eclipse.org/bugs
Hope this helps,
Eric
FUDForum. Page generated in 0.07218 seconds
