Re: Extension point not found [message #267673 is a reply to message #267651] |
Wed, 18 August 2004 23:27 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: Chris_Laffra.ca.ibm.com
This may help: eclipse -clean
Do you see any messages in the log?
What do you see in Window>Show View>Other..>PDE Runtime>Plug-in Registry?
Is your plug-in really loaded?
Chris
"Derek Adams" <derek_a_adams@yahoo.com> wrote in message
news:cg0htd$fe0$1@eclipse.org...
> I have a plugin that declares an extension point and a second plugin that
> makes a contribution to the extension point in the first plugin. If I run
> the plugins in the runtime workbench, the extension point is found and
> everything works. If I export the plugins as an archive and install them,
> the extension point is no longer found. The plugin.xml in the plugin
> folder shows the extension point and the schema is inlcluded in the plugin
> as well. When I make a call to
> Platform.getExtensionRegistry().getExtensionPoint(id), it returns null in
> the standard workbench. It returns the expected extension point in the
> runtime workbench.
> Any ideas?
> Derek
FUDForum. Page generated in 0.02919 seconds
