Re: How to attach debugger to running process? [message #262684 is a reply to message #262675] |
Tue, 20 July 2004 12:49  |
Originally posted by: pspiro.timberhill.com
That's excellent, thank you!
-Pete
Eric Rizzo wrote:
> Pete wrote:
> > Can someone tell me how to run the debugger and attach to a running
> > process?
> Assuming a) the process was started with the appropriate debug options
> to the JVM, and b) you are using Eclipse 3.0:
> 1) Switch to the Debug perspective.
> 2) From the Run menu, choose Debug... (or use the Debug button on the
> toolbar)
> 3) In the Run Configurations dialog, choose Remote Java Application and
> hit the New button.
> 4) Fill out the details to create the remote debug configuration.
> 5) Click Debug button when you've filled in all values. Eclipse will
> attempt to attach to the running process.
> From then on, that run configuration you created can be accessed with
> the Debug toolbar button when in Debug Perspective.
> HTH,
> Eric
FUDForum. Page generated in 0.05902 seconds
