Problems with Eclipse on Fedora 9 [message #261628] |
Mon, 21 July 2008 20:46 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: bill.davidson.gmail.com
I think this is probably a Fedora problem but I'm curious if
others have seen it.
With straight out of the box Fedora 9 and Europa or Ganymede,
JEE distribution, everything is fine. One day, after running
Fedora updates, this problem started happening.
I'm using Sun's JDK 1.6u7 via a -vm argument to Eclipse.
This problem also happened with 1.6u6.
If I run Fedora updates, then Eclipse crashes after a short
while because it runs out of memory. This is with -Xmx1024M.
It worked fine before with -Xmx512M. I've reverted to a fresh
Fedora 9 image so that I can keep working but I'd prefer to run
updates because of security. Sometimes the JVM actually crashes
and there appears to be a problem with realloc().
I've tried it with a few re-installs of Fedora. It doesn't
matter if I run Fedora updates with pup or yum.
I'm thinking about switching to Ubuntu.
Re: Problems with Eclipse on Fedora 9 [message #261635 is a reply to message #261628] |
Mon, 21 July 2008 21:08 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: codeslave.ca.ibm.com
http://wiki.eclipse.org/IRC_FAQ#I.27m_having_memory.2C_heap. 2C_or_permgen_problems.2C_what_can_I_do.3F
Try increasing the available permgen space.
Nick Boldt :: Release Engineer, IBM Toronto Lab
Eclipse Modeling :: http://www.eclipse.org/modeling
http://wiki.eclipse.org/index.php/User:Nickb
Re: Problems with Eclipse on Fedora 9 [message #261721 is a reply to message #261716] |
Tue, 22 July 2008 18:19 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Nick Boldt wrote:
> Ah, so it's the Fedora-distributed, Fedora-supported rpm(s) for the JDK
> and/or Eclipse that's corrupt?
No. I'm using Sun's JVM (JDK 1.6u7) and I'm not using the RPM's.
I just use the simple ".bin" unpack distribution. I believe it's
glibc that's been broken (errors in realloc()). Everything works as
long as I run a fresh install of Fedora 9 and don't run Fedora updates.
If I run Fedora updates, then the libraries go bad and Sun's JVM breaks.
It doesn't break immediately. I can usually run for about 10-20 minutes
in Eclipse before either Eclipse or the JVM crashes.
I'm considering Ubuntu, hoping they haven't put a borked glibc into
their distribution and hoping they do support sshfs (which I need).
> If so, why not ask for help from... um, Fedora?
Not sure where to ask. Also, I was just asking here if anyone else had
seen it. I wasn't really asking for a solution. Of course if someone
had a solution and shared it, that would be nice.
FUDForum. Page generated in 0.06164 seconds
