Home » Newcomers » Newcomers » Can't get Ganymede going right? data explorer
Can't get Ganymede going right? data explorer [message #258073] Wed, 11 June 2008 00:39 Go to next message
Tom Brander is currently offline Tom BranderFriend
Member
Have reinstalled Ganymede (reporting package) several times Latest
download and install was today. To use Birt, but cannot get the data
explorer to function with Mysql data base,, Have used the latest drivers
(jdbc) from Mysql.. The data base pings after install and database
configuration with driver, but no views of the data or options to create
data source??
Error log attached.
Help!
I've been at this for several days now...but wanted to exhaust my options
before posting..
Thanks!
!SESSION 2006-11-04 12:08:20.970
eclipse.buildId=I20060602-1317
java.version=1.5.0_06
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.help.base 4 0 2006-11-04 12:15:01.782
!MESSAGE The embedded application server could not run help web
application.
!STACK 1
org.eclipse.core.runtime.CoreException: Exception occurred starting
application server.
at
org.eclipse.tomcat.internal.TomcatAppServer.start(TomcatAppS erver.java:271)
at
org.eclipse.help.internal.appserver.AppserverPlugin.startWeb appServer(AppserverPlugin.java:143)
at
org.eclipse.help.internal.appserver.AppserverPlugin.getAppSe rver(AppserverPlugin.java:41)
at
org.eclipse.help.internal.appserver.WebappManager.start(Weba ppManager.java:58)
at
org.eclipse.help.internal.base.BaseHelpSystem.ensureWebappRu nning(BaseHelpSystem.java:246)
at
org.eclipse.help.internal.base.HelpDisplay.displayHelpURL(He lpDisplay.java:164)
at
org.eclipse.help.internal.base.HelpDisplay.displayHelpResour ce(HelpDisplay.java:86)
at
org.eclipse.help.ui.internal.DefaultHelpUI.displayHelpResour ce(DefaultHelpUI.java:231)
at
org.eclipse.ui.internal.help.WorkbenchHelpSystem.displayHelp Resource(WorkbenchHelpSystem.java:911)
at
org.eclipse.ui.help.WorkbenchHelp.displayHelpResource(Workbe nchHelp.java:116)
at
org.eclipse.birt.report.designer.ui.actions.cheatsheets.Open HelpAction.run(OpenHelpAction.java:31)
at
org.eclipse.ui.internal.cheatsheets.ActionRunner.runAction(A ctionRunner.java:86)
at org.eclipse.ui.internal.cheatsheets.data.Action.execute(Acti on.java:97)
at
org.eclipse.ui.internal.cheatsheets.views.CoreItem.runExecut able(CoreItem.java:476)
at
org.eclipse.ui.internal.cheatsheets.views.CoreItem.runExecut able(CoreItem.java:471)
at
org.eclipse.ui.internal.cheatsheets.views.CheatSheetViewer.r unPerformExecutable(CheatSheetViewer.java:991)
at
org.eclipse.ui.internal.cheatsheets.views.CoreItem$1.linkAct ivated(CoreItem.java:91)
at
org.eclipse.ui.forms.widgets.AbstractHyperlink.handleActivat e(AbstractHyperlink.java:208)
at
org.eclipse.ui.forms.widgets.ImageHyperlink.handleActivate(I mageHyperlink.java:174)
at
org.eclipse.ui.forms.widgets.AbstractHyperlink.handleMouseUp (AbstractHyperlink.java:289)
at
org.eclipse.ui.forms.widgets.AbstractHyperlink.access$1(Abst ractHyperlink.java:273)
at
org.eclipse.ui.forms.widgets.AbstractHyperlink$4.handleEvent (AbstractHyperlink.java:110)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3348)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2968)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
!SUBENTRY 1 org.eclipse.tomcat 4 0 2006-11-04 12:15:01.798
!MESSAGE Exception occurred starting application server.
!SESSION 2006-11-04 13:25:02.251
!ENTRY org.eclipse.ui 4 4 2006-11-04 13:38:31.595
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 2006-11-04 13:38:31.595
!MESSAGE Argument cannot be null
!STACK 0
java.lang.IllegalArgumentException: Argument cannot be null
at org.eclipse.swt.SWT.error(SWT.java:3358)
at org.eclipse.swt.SWT.error(SWT.java:3297)
at org.eclipse.swt.SWT.error(SWT.java:3268)
at org.eclipse.swt.widgets.Widget.error(Widget.java:435)
at org.eclipse.swt.widgets.Text.setText(Text.java:1649)
at
org.eclipse.birt.report.designer.data.ui.datasource.Connecti onProfileSelectionPage$3.widgetSelected(ConnectionProfileSel ectionPage.java:147)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:820 )
at org.eclipse.jface.window.Window.open(Window.java:796)
at
org.eclipse.birt.report.designer.ui.actions.NewDataSourceAct ion.run(NewDataSourceAction.java:83)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:499 )
at
org.eclipse.ui.actions.RetargetAction.runWithEvent(RetargetA ction.java:229)
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:539)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
at
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at
at
at
at
at
at
!ENTRY org.eclipse.ui 4 4 2006-11-04 13:41:41.626
!ENTRY org.eclipse.ui 4 0 2006-11-04 13:41:41.626
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.ui 4 4 2006-11-04 13:46:53.751
!ENTRY org.eclipse.ui 4 0 2006-11-04 13:46:53.751
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.birt.data 4 1001 2006-11-04 15:49:22.064
!MESSAGE A BIRT exception occurred.
!STACK 0
org.eclipse.birt.data.engine.core.DataException: Cannot execute the
statement.
Invalid
at
org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.e xecute(PreparedStatement.java:567)
at
org.eclipse.birt.data.engine.executor.DataSourceQuery.execut e(DataSourceQuery.java:482)
at
org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery$OdaDSQu eryExecutor.executeOdiQuery(PreparedOdaDSQuery.java:330)
at
org.eclipse.birt.data.engine.impl.QueryExecutor.execute(Quer yExecutor.java:735)
at
org.eclipse.birt.data.engine.impl.ServiceForQueryResults.exe cuteQuery(ServiceForQueryResults.java:181)
at
org.eclipse.birt.data.engine.impl.QueryResults.getResultIter ator(QueryResults.java:137)
at
org.eclipse.birt.report.designer.data.ui.dataset.ResultSetPr eviewPage.populateRecords(ResultSetPreviewPage.java:430)
at
org.eclipse.birt.report.designer.data.ui.dataset.ResultSetPr eviewPage.access$200(ResultSetPreviewPage.java:83)
at
org.eclipse.birt.report.designer.data.ui.dataset.ResultSetPr eviewPage$5.run(ResultSetPreviewPage.java:379)
at
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:113)
Caused by: org.eclipse.datatools.connectivity.oda.OdaException: Invalid
at
org.eclipse.datatools.connectivity.oda.flatfile.FlatFileQuer y.splitStringWithDoubleQuotes(FlatFileQuery.java:936)
at
org.eclipse.datatools.connectivity.oda.flatfile.FlatFileQuer y.fetchQueriedDataFromRow(FlatFileQuery.java:850)
at
org.eclipse.datatools.connectivity.oda.flatfile.FlatFileQuer y.fetchQueriedDataFromFileToVector(FlatFileQuery.java:822)
at
org.eclipse.datatools.connectivity.oda.flatfile.FlatFileQuer y.executeQuery(FlatFileQuery.java:161)
at
org.eclipse.datatools.connectivity.oda.consumer.helper.OdaQu ery.doExecuteQuery(OdaQuery.java:443)
at
org.eclipse.datatools.connectivity.oda.consumer.helper.OdaQu ery.executeQuery(OdaQuery.java:408)
at
org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.e xecute(PreparedStatement.java:553)
... 9 more
!SUBENTRY 1 org.eclipse.birt.data 1 1001 2006-11-04 15:49:22.064
!MESSAGE Plug-in Provider:Eclipse.org
!MESSAGE Plug-in Name:BIRT Data Engine
!MESSAGE Plug-in ID:org.eclipse.birt.data
!MESSAGE Version:2.1.1.v20060922-1058
!SUBENTRY 1 org.eclipse.birt.data 4 1001 2006-11-04 15:49:22.064
!MESSAGE Error Code:odaconsumer.CannotExecuteStatement
!MESSAGE Error Message:Cannot execute the statement.
Invalid
Re: Can't get Ganymede going right? data explorer [message #258097 is a reply to message #258073] Wed, 11 June 2008 12:31 Go to previous messageGo to next message
Originally posted by: codeslave.ca.ibm.com
Copying to BIRT & EPP newsgroups.
> create data source?? Error log attached.
> Help!
> options before posting..
> Thanks!
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> application.
> !STACK 1
> application server.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> statement.
> Invalid
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 9 more
> Invalid
Nick Boldt :: Release Engineer, IBM Toronto Lab
Eclipse Modeling :: http://www.eclipse.org/modeling
http://wiki.eclipse.org/index.php/User:Nickb
Re: Can't get Ganymede going right? data explorer [message #258101 is a reply to message #258097] Wed, 11 June 2008 12:48 Go to previous messageGo to next message
Member
Thanks for the follow-up. Found the Birt group but what is EPP?
Tom
Re: Can't get Ganymede going right? data explorer [message #258103 is a reply to message #258101] Wed, 11 June 2008 13:04 Go to previous messageGo to next message
EPP == Eclipse Packaging Project
http://www.eclipse.org/epp/
This is the project responsible for building the Europa and Ganymede
bundles.
> Tom
Re: Can't get Ganymede going right? data explorer [message #258112 is a reply to message #258101] Wed, 11 June 2008 13:34 Go to previous messageGo to next message
> Tom
Maybe you should open a bug against this package.
Go back to the page where you downloaded the reporting package
(http://www.eclipse.org/downloads/packages/), click on the 'More...' link
of the 'Eclipse IDE for Java and Report Developers' package. On the
following page, you'll find a link 'File a Bug on this Package' on the
bottom right.
This will help the BIRT team by reproducing and fixing this bug.
Markus
Re: Can't get Ganymede going right? data explorer [message #258130 is a reply to message #258112] Wed, 11 June 2008 14:46 Go to previous messageGo to next message
Member
Thanks, filed a bug report as suggested.
Tom
Re: Can't get Ganymede going right? data explorer [message #258134 is a reply to message #258112] Wed, 11 June 2008 14:51 Go to previous messageGo to next message
Member
Bug report filed as requested.
Re: Can't get Ganymede going right? data explorer [message #258199 is a reply to message #258112] Wed, 11 June 2008 21:56 Go to previous messageGo to next message
Member
bug #236647 opened
Thanks...
Re: Can't get Ganymede going right? data explorer [message #258527 is a reply to message #258199] Fri, 13 June 2008 16:54 Go to previous message
Member
So far the bug responder indicates they cannot reproduce the problem...
Does anyone have an idea of what I can do next, It seems to me that having
done a clean install,on a win xp sp3 box with a new workspace I should be
good to go I used the all in one report install of Ganymede RC3. But I'm
not and I don't even have an error message to go on... I'm willing to
assume that it is my user error but I still need to get past this. It
seems that the problem is in the data explorer component, but I've
rechecked my installation as far as I can, and it looks good. I'd sure
like to get this thing talking to Mysql for the weekend. Any Ideas???
Previous Topic:Transferring String data from pop-up meu action to view
Next Topic:How to link multipage editor to source code file?
Current Time: Thu Nov 07 13:18:19 GMT 2024
Powered by FUDForum. Page generated in 0.08307 seconds
