Can't get Ganymede going right? data explorer [message #258073] |
Wed, 11 June 2008 00:39 |
Tom Brander Messages: 30 Registered: July 2009 |
Member |
Have reinstalled Ganymede (reporting package) several times Latest
download and install was today. To use Birt, but cannot get the data
explorer to function with Mysql data base,, Have used the latest drivers
(jdbc) from Mysql.. The data base pings after install and database
configuration with driver, but no views of the data or options to create
data source??
Error log attached.
Help!
I've been at this for several days now...but wanted to exhaust my options
before posting..
Thanks!
!SESSION 2006-11-04 12:08:20.970
eclipse.buildId=I20060602-1317
java.version=1.5.0_06
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.help.base 4 0 2006-11-04 12:15:01.782
!MESSAGE The embedded application server could not run help web
application.
!STACK 1
org.eclipse.core.runtime.CoreException: Exception occurred starting
application server.
at
org.eclipse.tomcat.internal.TomcatAppServer.start(TomcatAppS erver.java:271)
at
org.eclipse.help.internal.appserver.AppserverPlugin.startWeb appServer(AppserverPlugin.java:143)
at
org.eclipse.help.internal.appserver.AppserverPlugin.getAppSe rver(AppserverPlugin.java:41)
at
org.eclipse.help.internal.appserver.WebappManager.start(Weba ppManager.java:58)
at
org.eclipse.help.internal.base.BaseHelpSystem.ensureWebappRu nning(BaseHelpSystem.java:246)
at
org.eclipse.help.internal.base.HelpDisplay.displayHelpURL(He lpDisplay.java:164)
at
org.eclipse.help.internal.base.HelpDisplay.displayHelpResour ce(HelpDisplay.java:86)
at
org.eclipse.help.ui.internal.DefaultHelpUI.displayHelpResour ce(DefaultHelpUI.java:231)
at
org.eclipse.ui.internal.help.WorkbenchHelpSystem.displayHelp Resource(WorkbenchHelpSystem.java:911)
at
org.eclipse.ui.help.WorkbenchHelp.displayHelpResource(Workbe nchHelp.java:116)
at
org.eclipse.birt.report.designer.ui.actions.cheatsheets.Open HelpAction.run(OpenHelpAction.java:31)
at
org.eclipse.ui.internal.cheatsheets.ActionRunner.runAction(A ctionRunner.java:86)
at org.eclipse.ui.internal.cheatsheets.data.Action.execute(Acti on.java:97)
at
org.eclipse.ui.internal.cheatsheets.views.CoreItem.runExecut able(CoreItem.java:476)
at
org.eclipse.ui.internal.cheatsheets.views.CoreItem.runExecut able(CoreItem.java:471)
at
org.eclipse.ui.internal.cheatsheets.views.CheatSheetViewer.r unPerformExecutable(CheatSheetViewer.java:991)
at
org.eclipse.ui.internal.cheatsheets.views.CoreItem$1.linkAct ivated(CoreItem.java:91)
at
org.eclipse.ui.forms.widgets.AbstractHyperlink.handleActivat e(AbstractHyperlink.java:208)
at
org.eclipse.ui.forms.widgets.ImageHyperlink.handleActivate(I mageHyperlink.java:174)
at
org.eclipse.ui.forms.widgets.AbstractHyperlink.handleMouseUp (AbstractHyperlink.java:289)
at
org.eclipse.ui.forms.widgets.AbstractHyperlink.access$1(Abst ractHyperlink.java:273)
at
org.eclipse.ui.forms.widgets.AbstractHyperlink$4.handleEvent (AbstractHyperlink.java:110)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3348)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2968)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
!SUBENTRY 1 org.eclipse.tomcat 4 0 2006-11-04 12:15:01.798
!MESSAGE Exception occurred starting application server.
!SESSION 2006-11-04 13:25:02.251
!ENTRY org.eclipse.ui 4 4 2006-11-04 13:38:31.595
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 2006-11-04 13:38:31.595
!MESSAGE Argument cannot be null
!STACK 0
java.lang.IllegalArgumentException: Argument cannot be null
at org.eclipse.swt.SWT.error(SWT.java:3358)
at org.eclipse.swt.SWT.error(SWT.java:3297)
at org.eclipse.swt.SWT.error(SWT.java:3268)
at org.eclipse.swt.widgets.Widget.error(Widget.java:435)
at org.eclipse.swt.widgets.Text.setText(Text.java:1649)
at
org.eclipse.birt.report.designer.data.ui.datasource.Connecti onProfileSelectionPage$3.widgetSelected(ConnectionProfileSel ectionPage.java:147)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:820 )
at org.eclipse.jface.window.Window.open(Window.java:796)
at
org.eclipse.birt.report.designer.ui.actions.NewDataSourceAct ion.run(NewDataSourceAction.java:83)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:499 )
at
org.eclipse.ui.actions.RetargetAction.runWithEvent(RetargetA ction.java:229)
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:539)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
at
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at
at
at
at
at
at
!ENTRY org.eclipse.ui 4 4 2006-11-04 13:41:41.626
!ENTRY org.eclipse.ui 4 0 2006-11-04 13:41:41.626
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.ui 4 4 2006-11-04 13:46:53.751
!ENTRY org.eclipse.ui 4 0 2006-11-04 13:46:53.751
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.birt.data 4 1001 2006-11-04 15:49:22.064
!MESSAGE A BIRT exception occurred.
!STACK 0
org.eclipse.birt.data.engine.core.DataException: Cannot execute the
statement.
Invalid
at
org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.e xecute(PreparedStatement.java:567)
at
org.eclipse.birt.data.engine.executor.DataSourceQuery.execut e(DataSourceQuery.java:482)
at
org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery$OdaDSQu eryExecutor.executeOdiQuery(PreparedOdaDSQuery.java:330)
at
org.eclipse.birt.data.engine.impl.QueryExecutor.execute(Quer yExecutor.java:735)
at
org.eclipse.birt.data.engine.impl.ServiceForQueryResults.exe cuteQuery(ServiceForQueryResults.java:181)
at
org.eclipse.birt.data.engine.impl.QueryResults.getResultIter ator(QueryResults.java:137)
at
org.eclipse.birt.report.designer.data.ui.dataset.ResultSetPr eviewPage.populateRecords(ResultSetPreviewPage.java:430)
at
org.eclipse.birt.report.designer.data.ui.dataset.ResultSetPr eviewPage.access$200(ResultSetPreviewPage.java:83)
at
org.eclipse.birt.report.designer.data.ui.dataset.ResultSetPr eviewPage$5.run(ResultSetPreviewPage.java:379)
at
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:113)
Caused by: org.eclipse.datatools.connectivity.oda.OdaException: Invalid
at
org.eclipse.datatools.connectivity.oda.flatfile.FlatFileQuer y.splitStringWithDoubleQuotes(FlatFileQuery.java:936)
at
org.eclipse.datatools.connectivity.oda.flatfile.FlatFileQuer y.fetchQueriedDataFromRow(FlatFileQuery.java:850)
at
org.eclipse.datatools.connectivity.oda.flatfile.FlatFileQuer y.fetchQueriedDataFromFileToVector(FlatFileQuery.java:822)
at
org.eclipse.datatools.connectivity.oda.flatfile.FlatFileQuer y.executeQuery(FlatFileQuery.java:161)
at
org.eclipse.datatools.connectivity.oda.consumer.helper.OdaQu ery.doExecuteQuery(OdaQuery.java:443)
at
org.eclipse.datatools.connectivity.oda.consumer.helper.OdaQu ery.executeQuery(OdaQuery.java:408)
at
org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.e xecute(PreparedStatement.java:553)
... 9 more
!SUBENTRY 1 org.eclipse.birt.data 1 1001 2006-11-04 15:49:22.064
!MESSAGE Plug-in Provider:Eclipse.org
!MESSAGE Plug-in Name:BIRT Data Engine
!MESSAGE Plug-in ID:org.eclipse.birt.data
!MESSAGE Version:2.1.1.v20060922-1058
!SUBENTRY 1 org.eclipse.birt.data 4 1001 2006-11-04 15:49:22.064
!MESSAGE Error Code:odaconsumer.CannotExecuteStatement
!MESSAGE Error Message:Cannot execute the statement.
Invalid
Re: Can't get Ganymede going right? data explorer [message #258097 is a reply to message #258073] |
Wed, 11 June 2008 12:31 |
Originally posted by: codeslave.ca.ibm.com
Copying to BIRT & EPP newsgroups.
> create data source?? Error log attached.
> Help!
> options before posting..
> Thanks!
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> application.
> !STACK 1
> application server.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> statement.
> Invalid
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 9 more
> Invalid
Nick Boldt :: Release Engineer, IBM Toronto Lab
Eclipse Modeling :: http://www.eclipse.org/modeling
http://wiki.eclipse.org/index.php/User:Nickb
Re: Can't get Ganymede going right? data explorer [message #258112 is a reply to message #258101] |
Wed, 11 June 2008 13:34 |
Originally posted by: mknauer.innoopract.com
Tom Brander wrote:
> Thanks for the follow-up. Found the Birt group but what is EPP?
> Tom
Maybe you should open a bug against this package.
Go back to the page where you downloaded the reporting package
(http://www.eclipse.org/downloads/packages/), click on the 'More...' link
of the 'Eclipse IDE for Java and Report Developers' package. On the
following page, you'll find a link 'File a Bug on this Package' on the
bottom right.
This will help the BIRT team by reproducing and fixing this bug.
Markus
FUDForum. Page generated in 0.10219 seconds
