Home » Newcomers » Newcomers » junit and external file
junit and external file [message #257985] Tue, 10 June 2008 11:25 Go to next message
hi all
I have to make junit test with external file in simple
I have to open a file , read some data , (see if there are correct) etc..;
le prob is how to have the same path even if test move to another pc.
my best solution is put that on the jar itself but what is the reltive
path of the current jar??
thanks
a++
Re: junit and external file [message #258014 is a reply to message #257985] Tue, 10 June 2008 13:00 Go to previous messageGo to next message
YOur first and best choice is to include the file in the JAR and use the
Class.getResourceAsStream() method to get it. This, however, doesn't
work so well if you have to write to the file. It does have the benefit
of working anywhere, including a JAR or bundle.
Another option is to explicitly set the working directory in your launch
configuration (on the Arguments tab).
HTH,
Wayne
On Tue, 2008-06-10 at 17:25 +0200, julien wrote:
> hi all
> thanks
> a++
Re: junit and external file [message #258083 is a reply to message #258014] Wed, 11 June 2008 00:58 Go to previous message
> HTH,
> Wayne
>> hi all
>> thanks
>> a++
thanks,
I ll look
a++
Previous Topic:why can't I repeat the drawing button in Editor of Eclipse?
Next Topic:Right-click hangs UI
Current Time: Fri Oct 17 00:04:09 EDT 2025
Powered by FUDForum. Page generated in 0.10051 seconds
