Re: Linked CSS styles and relative path [message #256571 is a reply to message #256480] |
Fri, 28 September 2007 15:35 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: jasonweathersby.alltel.net
Jeff,
Are you using the WebViewer or the engine API?
If you are using the Web Viewer look at the web.xml there is a setting
for resource path, which can be set relative to the context. If you are
using the engine API you should be able to set to wherever you want.
Jason
Jeff Ramsdale wrote:
> I'm using linked CSS as described in the Styles Revisited post on BIRT
> World. Works great in the report designer. When I try to run my report,
> though, my styles disappear.
> I gather from this thread:
> < http://dev.eclipse.org/newslists/news.eclipse.birt/msg20240. html> that
> I need to set the resource path for the engine config. The sample code
> provided from Jason uses an absolute path, though, and my CSS file and
> report are embedded in an Eclipse plugin.
> Can I use a relative path here? (And relative to what?) Or a platform
> URL or some-such? I'm having trouble finding where to put a breakpoint
> to figure out how the path is evaluated.
> Jeff
Re: Linked CSS styles and relative path [message #256602 is a reply to message #256578] |
Fri, 28 September 2007 16:59 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Jeff,
If your resources are in a plugin, can you use something like:
Bundle bundle =
org.eclipse.core.runtime.Platform.getBundle("my.resource.plugin ");
config.setResourcePath(config.bundle.getEntry("pathinplugin "));
Jason
> Jason,
> I'm using the engine API. Since my styles don't show up but neither do I
> get any exceptions I'm wondering where the path gets resolved and how I
> determine why it didn't work. For instance, if I use a relative path how
> do I tell what it's resolved against?
> Jeff
> Jason Weathersby wrote:
>> Jeff,
>> are using the engine API you should be able to set to wherever you want.
>> Jason
>>> BIRT World. Works great in the report designer. When I try to run my
>>> report, though, my styles disappear.
>>> that I need to set the resource path for the engine config. The
>>> sample code provided from Jason uses an absolute path, though, and my
>>> CSS file and report are embedded in an Eclipse plugin.
>>> breakpoint to figure out how the path is evaluated.
>>> Jeff
FUDForum. Page generated in 0.04217 seconds
