Sources generated by APT are not compiled to output folder [message #255513] |
Mon, 11 August 2008 21:34 |
Originally posted by: adv.zahn.googlemail.com
I have a Java Project with an Annotation Processor, generating some
source code to a source folder. Unfortunately, the generated source code
is not compiled to the "bin" output folder.
The annotation processor is my own one, and after generating the source
code, I call the following lines:
final IFolder genFolder = ...;
if(null != genFolder)
try {
genFolder.refreshLocal(IResource.DEPTH_INFINITE, monitor);
} catch (CoreException e1) {
What am I missing?
Greetings,
Ralf
Re: Sources generated by APT are not compiled to output folder [message #255517 is a reply to message #255513] |
Mon, 11 August 2008 21:43 |
Okay, might be the fact that I do not use the filer, I just use a code
generator generating the source file into the folder.
Ralf Zahn schrieb:
> Hello,
> try {
> What am I missing?
> Greetings,
> Ralf
Re: Sources generated by APT are not compiled to output folder [message #255524 is a reply to message #255521] |
Tue, 12 August 2008 09:27 |
Okay, but I had to use another source folder because (in the Annotation
Processor) I call an external code generator that does not use the Filer
object.
> You definitely need to use Filer. It will not work otherwise. Filer
> informs the Java compiler that new types have been created and restarts
> the compilation loop.
Re: Sources generated by APT are not compiled to output folder [message #255530 is a reply to message #255524] |
Tue, 12 August 2008 15:34 |
Walter Harley Messages: 847 Registered: July 2009 |
"Ralf Zahn" <adv.zahn@googlemail.com> wrote in message
news:g7rl1i$4ru$1@build.eclipse.org...
> object.
I understand your use case. Unfortunately this is a limitation of the way
that APT, and the Eclipse java compiler, work. If you want types generated
within an APT pass to be compiled, you need to generate them with the Filer.
I expect the same would be true, by the way, if you were using Sun's apt and
javac.
One option, if you can't change the external code generator, is have it
generate into a temp directory, and then have the annotation processor read
the contents of that directory and use Filer to generate the "real" files.
FUDForum. Page generated in 0.04424 seconds
