Linux Configurations with Multiple Users and multiple products. [message #255400] |
Thu, 24 June 2004 17:50 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: manahan.NOSPAM.ca.ibm.com
Currently (3.0) if the installation directory is readonly then eclipse
stores configuration information in the $HOME/.eclipse directory. This
works fine if you are only using one instance of eclipse. If you have a
couple of different products installed each running on an eclipse 3.0
the what is the method the products can use to make their user
configuration directory unique?
So I'd like to be able that instead of using $HOME/.eclipse I'd like to
be able to specify say $HOME/.myproduct.
Peter
Re: Linux Configurations with Multiple Users and multiple products. [message #255512 is a reply to message #255400] |
Fri, 25 June 2004 02:52 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Originally posted by: pascal.ibm.canada
If I'm correct, this should happen for free if a product is defined in
your application and listed in your config.ini (eclipse.product).
If this is not the case, you can set in your shared install the
"osgi.baseConfiguration.area" property to "@user.home/.bar".
This value is read very early in the boot process, interpreted and then
used as the configuration area.
Let me know if this works. I'm telling you all that from memory.
PaScaL
Peter Manahan wrote:
> Hello,
> eclipse stores configuration information in the $HOME/.eclipse
> directory. This works fine if you are only using one instance of
> eclipse. If you have a couple of different products installed each
> running on an eclipse 3.0 the what is the method the products can use to
> make their user configuration directory unique?
> Peter
FUDForum. Page generated in 0.03416 seconds
