| PEAR question [message #25427] |
Mon, 04 June 2007 21:56  |
Originally posted by: dom061077.gmail.com
Hi! How Can I run my PEAR php files in eclipse PDT??It's like PEAR classes
can't be parses
| Re: PEAR question [message #25753 is a reply to message #25468] |
Tue, 05 June 2007 13:08   |
It doesn't work...when I Run it as "PHP Script" the Browser Output only
show me html source code instead page. The source code is:
<?php
require_once 'Auth.php';
require_once 'HTML/Form.php';
function showLogin() {
/* Use the HTML_Form class to show our login form
echo "<html><head></head><body>";
$form = new HTML_Form(htmlspecialchars($_SERVER['PHP_SELF']), 'post');
$form->addText('username', 'Username:');
$form->addPasswordOne('password', 'Password:');
$form->addSubmit('submit', 'Login');
$form->display();
echo "You are not currently logged in!";
echo "</body></html>";
$options = array (
'dsn' => 'mysql://root:luque@localhost/calendar',
'table' => 'users',
'usernamecol' => 'user_id',
'passwordcol' => 'password',
'crypttype' => 'md5'
$dsn = 'mysql://root:luque@localhost/calendar';
$a = new Auth("DB", $options, 'showLogin');
$a->start();
if ($a->checkAuth()) {
header('location:calendar.php');
The Browser Output show me:
X-Powered-By: PHP/5.2.0
Set-Cookie: ZendDebuggerCookie=127.0.0.1%3A10000%3A0||004|77742D65|1000;
path=/
Set-Cookie: PHPSESSID=16c7ca91ce8a8fd7116c24bec5630ea6; path=/
Expires: Thu, 19 Nov 1981 08:52:00 GMT
Cache-Control: no-store, no-cache, must-revalidate, post-check=0,
pre-check=0
Pragma: no-cache
Content-type: text/html
<html><head></head><body><form action="C:\Archivos de programa\Apache
Group\Apache2\htdocs\webcalendar\login.php" method="post" >
<table >
<tr>
<th align="right" valign="top">Username:</th>
<td >
<input type="text" name="username" size="20" value="" />
</td>
</tr>
<tr>
<th align="right" valign="top">Password:</th>
<td >
<input type="password" name="password" size="8" value="" />
</td>
</tr>
<tr>
<th align="right" valign="top"> </th>
<td >
<input type="submit" name="submit" value="Login" />
</td>
</tr>
</table>
<input type="hidden" name="_fields" value="username:password:submit" />
</form>
You are not currently logged in!</body></html>
Thanks a lot!
| Re: PEAR question [message #25759 is a reply to message #25753] |
Tue, 05 June 2007 18:18   |
Originally posted by: andrescpaz-eclipse.yahoo.com
Hi Daniel,
I don't understand your question, but since you're generating HTML I think you want to run this script as "PHP Web Page" and not as "PHP Script", that's to run command line scripts.
What you got was not a browser output, but the command line output.
-a.
> <?php
> $form->display();
> $options = array (
> 'table' => 'users',
> $a->start();
> path=/
> pre-check=0
> Pragma: no-cache
> <table >
> <tr>
> <td >
> </td>
> </tr>
> <tr>
> <td >
> </td>
> </tr>
> <tr>
> <td >
> </td>
> </tr>
> </table>
> </form>
> Thanks a lot!
| Re: PEAR question [message #27059 is a reply to message #26059] |
Fri, 08 June 2007 19:37  |
Originally posted by: nobody.fergusonv.com
I think that your inclusion of the PEAR code is causing an error, and
your webserver/PHP is configured to not display errors, resulting in a
404. I would recommend enabling 'display_errors' in your test environment.
tjjfv
Daniel wrote:
> Ok,but when I go to "Run->Run As->PHP Web Page" It doens't work. The web
> browser into eclipse shows me "Page Not Found". By the way,the php
> source code without PEAR works fine into "Browser Output" and it shows
> me Web Page Not HTML source code.
> Thanks
FUDForum. Page generated in 0.06165 seconds
