crosstab dimension drilldown [message #254122] |
Sat, 01 September 2007 04:10 |
Originally posted by: spaddock.rogers.com
Instead of showing all possible dimension levels, is it possible to
drill-down into them.
For example, in the common product line crosstab example what if you
wanted to drill-down into the motorcycle product line and see how the
different motorcycles were doing.
With the Mondrian product you see the cubes with the typical (+) interface
to expand the dimensions, is this possible in BIRT? if not is it planned?
Shayne
Re: crosstab dimension drilldown [message #254434 is a reply to message #254153] |
Tue, 04 September 2007 15:34 |
For now I could create two different report designs and just have a
hyperlink.
Is there a way to use the cube in multiple reports? Most of the work is
done building the cube so it would be a shame to have to recreate the same
cube for multiple reports.
Great news about it being available in 2.3.1
Kindest regards,
Shayne
Re: crosstab dimension drilldown [message #254500 is a reply to message #254496] |
Wed, 05 September 2007 02:09 |
What I meant was to be able to reuse the same cube that just got populated
full of data from the previous report.
Are you saying it's possible to reuse the cube in other reports once it's
calculated all it's dimensions and measures? Obviously within a
reasonable amount of time without being refreshed.
At design time the cube is simple to build. At runtime complex cubes take
a while to generate.
-Shayne
Tianli wrote:
> Of course you can, define your cube in a rptlibrary and publish the
> library. Then others reports can use this cube from library.
> Best regards!
> Tianli
FUDForum. Page generated in 0.04656 seconds
