Home » Eclipse Projects » Eclipse Platform » How tro obtain the absolute install path of a plugin?
How tro obtain the absolute install path of a plugin? [message #253886] Fri, 18 June 2004 09:52 Go to next message
Originally posted by: fabien.mairesse.barco.com
I can't obtain the absolute install path of my plugin. I didn't find any
suitable methods in class Platform. I've tried
IPLuginDescriptor::getInstallURL() but the returned URL is :
"/plugin/my_plugin_directory/" (I don't understand this URL because my
plugins are stored in the "plugins/" directory of the platform and the URL
contains "plugin/" (without 's'). So this URL is even not the relative
path of my plugin in the platform?)
What I want to do is accessing directly to a resource stored in my plugin
directory.
thanks in advance
Fabien
Re: How tro obtain the absolute install path of a plugin? [message #253894 is a reply to message #253886] Fri, 18 June 2004 10:07 Go to previous messageGo to next message
there is a method in Platform called "resolve" which resolved the URL
retrieved by getInstallURL. A call to ".getFile()" of the retrieved URL
gives you the absolute path on your system---like this:
String resolvedPath = Platform.resolve(<URL retrieved by
PluginDescriptor.getInstallURL()>).getFile();
Note however, that PluginDescriptor is deprecated in 3.0. I am not too
sure about it, but I _think_ the correct way to determine the installation
path of a plug-in in 3.0 is:
private String getResolvedPath(String pluginID) {
Bundle bundle = Platform.getBundle(pluginID);
if (bundle != null) {
URL bundleURL = bundle.getResource("/");
if (bundleURL != null) {
String resolvedPath;
try {
resolvedPath = Platform.resolve(bundleURL).getFile();
return resolvedPath;
} catch (IOException e) {
return null;
where "pluginID" is the id of your plug-in as defined in plugin.xml.
Hope that helps,
Philipp
> Hello,
> directory.
> thanks in advance
> Fabien
Re: How tro obtain the absolute install path of a plugin? [message #253906 is a reply to message #253894] Fri, 18 June 2004 10:35 Go to previous messageGo to next message
Originally posted by: richkulp.NO.SPAM.us.ibm.com
But be aware you may not always get a file url. It is possible,
depending on how things are installed, that you could get a URL pointing
into a jar, or even a url that exists on another system.
However, the default is currently a local file. Most installations don't
have the plugins zipped into a jar nor do they install remote.
Thanks, Rich Kulp
Re: How tro obtain the absolute install path of a plugin? [message #253931 is a reply to message #253894] Fri, 18 June 2004 11:22 Go to previous messageGo to next message
Originally posted by: paull.NOSPAMcodetelligence.com
I use
getBundle().getEntry("/")
Paul
www.codetelligence.com
"Philipp Bouillon" <Philipp.Bouillon@t-online.de> wrote in message
news:causvq$amt$1@eclipse.org...
> try {
> return null;
> Hope that helps,
> Philipp
> > Hello,
URL
plugin
> > directory.
> > thanks in advance
> > Fabien
thank you! [message #253935 is a reply to message #253894] Fri, 18 June 2004 11:23 Go to previous message
it works!! Thank you very much Philipp.
Philipp Bouillon wrote:
> try {
> return null;
> Hope that helps,
> Philipp
> > Hello,
> > directory.
> > thanks in advance
> > Fabien
Previous Topic:PDE - Target Platform (out of sync)
Next Topic:subclassing CloseEditorAction
Current Time: Fri Sep 19 00:26:23 EDT 2025
Powered by FUDForum. Page generated in 0.05671 seconds
