Home » Archived » BIRT » How sun.jdbc.odbc can read data in network ?
How sun.jdbc.odbc can read data in network ? [message #251438] |
Tue, 07 August 2007 09:45 |
Originally posted by: subianto.liawidjaya.planatations.co.id
I am trying BIRT data source with driver class :
sun.jdbc.odbc.JdbcOdbcDriver
then, at data source (Database URL) I fill : jdbc:odbc:posdbf
(* my odbc database is DBF, it's name : posdbf, and it's free table locate
at C:\POS\DATABASE)
I make data set and running the report design :
*. preview in Report-Design - Eclipse SDK = good
*. view report in Report-Design-Eclipse SDK = good
*. view with (tomcat+birt viewer 2.2), address http://localhost:8080/.... =
good
my problem is :
if ODBC (POSDBF) I set the data location in network, G:\POS\DATABASE
NO RESULT
if I read log, the error is :
SEVERE: Cannot get resultset metadata.
org.eclipse.birt.report.data.oda.jdbc.JDBCException: SQL statement does not
return a ResultSet object.
SQL error #1: [Microsoft][ODBC Visual FoxPro Driver]File 'operator.dbf' does
not exist.
java.sql.SQLException: [Microsoft][ODBC Visual FoxPro Driver]File
'operator.dbf' does not exist.
I am using WIN XP, and the server is WIN NT.
maybe I miss someting must set in tomcat or birt viewer 2.2 ?, anyone can
explain this case, please ?
Thanks.
Re: How sun.jdbc.odbc can read data in network ? [message #251531 is a reply to message #251438] |
Tue, 07 August 2007 17:58 |
Originally posted by: jasonweathersby.alltel.net
This looks like a permission issue. Can you try to setup the DSN and
use the network button, and specifically setup a username and password
to connect to the remove system?
Jason
> at C:\POS\DATABASE)
> good
> my problem is :
> NO RESULT
> not exist.
> Thanks.
Re: How sun.jdbc.odbc can read data in network ? [message #251827 is a reply to message #251531] |
Thu, 09 August 2007 00:45 |
Originally posted by: subianto.liawidjaya.plantations.co.id
Hi Jason,
Yes, when setup the DSN and choose the network button I have to map
network drive (map to G:\) and I can see the files (DBF files) when setup
the DSN.
But how I put the username and password in DSN ? because when I explore with
IE, the drive G shows files and FOXPRO can open the files (DBF files) in
drive G.
Thanks.
"Jason Weathersby" <jasonweathersby@alltel.net> wrote in message
news:f9abom$pk$1@build.eclipse.org...
> This looks like a permission issue. Can you try to setup the DSN and use
> the network button, and specifically setup a username and password to
> Jason
>> locate at C:\POS\DATABASE)
>> http://localhost:8080/.... = good
>> my problem is :
>> http://localhost:8080/.... = NO RESULT
>> not return a ResultSet object.
>> does not exist.
>> can explain this case, please ?
>> Thanks.
Re: How sun.jdbc.odbc can read data in network ? [message #251870 is a reply to message #251827] |
Thu, 09 August 2007 14:43 |
When you map the drive you have the option to use your username or
"Connect using a different use name". If your username is working this
should not be an issue. Is tomcat running as the same user you
connected the network drive with?
Jason
Bian wrote:
> Hi Jason,
> the DSN.
> drive G.
> Thanks.
>> Jason
>>> my problem is :
>>> does not exist.
>>> Thanks.
Re: How sun.jdbc.odbc can read data in network ? [message #251935 is a reply to message #251870] |
Fri, 10 August 2007 00:29 |
Jason,
I install tomcat in my computer (win XP) and login with the same user
that I connect to network drive.
Thanks.
news:f9f937$j60$1@build.eclipse.org...
> should not be an issue. Is tomcat running as the same user you connected
> Jason
> Bian wrote:
>> Hi Jason,
>> the DSN.
>> with IE, the drive G shows files and FOXPRO can open the files (DBF
>> files) in drive G.
>> Thanks.
>>> Jason
>>>> my problem is :
>>>> does not exist.
>>>> Thanks.
Re: How sun.jdbc.odbc can read data in network ? [message #251977 is a reply to message #251935] |
Fri, 10 August 2007 14:48 |
Bian,
Can you log a bugzilla entry for this.
Jason
Bian wrote:
> Jason,
> Thanks.
>> Jason
>> Bian wrote:
>>> Hi Jason,
>>> the DSN.
>>> files) in drive G.
>>> Thanks.
>>>> Jason
>>>>> my problem is :
>>>>> does not exist.
>>>>> Thanks.
Re: How sun.jdbc.odbc can read data in network ? [message #253494 is a reply to message #251977] |
Mon, 27 August 2007 03:18 |
Hi... Jason,
Actually I solve my problem (sun.jdbc.odbc... driver connect to database in
network with local odbc). The problem is at setting Tomcat.
After we install Tomcat 5.523, we must add some bat files to setting the
tomcat (I learn and copied the setting file from installing JASPER SERVER).
Now, my problem is solved.
thanks for your help Jason.
Bian.
news:f9hton$6sb$3@build.eclipse.org...
> Bian,
> Jason
> Bian wrote:
>> Jason,
>> user that I connect to network drive.
>> Thanks.
>>> Jason
>>> Bian wrote:
>>>> Hi Jason,
>>>> setup the DSN.
>>>> files) in drive G.
>>>> Thanks.
>>>>> Jason
>>>>>> my problem is :
>>>>>> G:\POS\DATABASE
>>>>>> does not return a ResultSet object.
>>>>>> anyone can explain this case, please ?
>>>>>> Thanks.
Current Time: Sun Oct 06 15:41:12 GMT 2024
Powered by FUDForum. Page generated in 0.04004 seconds
