Home » Eclipse Projects » Babel » No translations for Subversive
No translations for Subversive [message #25178] Fri, 06 March 2009 12:12 Go to next message
I wanted to run Babel Pseudo Translation Test to verify Subversive
translatablity (following to guidelines from Galileo Simultaneous release)
I just checked Babel Language Packs from nightly builds:
http://build.eclipse.org/technology/babel/test-updates/ganym ede and didn't
find any translations for Subversive project. (I checked nightly update site
because Babel Language Pack Update Site for Ganymede doesn't work, as was
already noted here in newsgroup).
Then I checked Subversive at translate
page(http://babel.eclipse.org/babel/translate.php) and Subversive project is
present there but there are no translations for it, despite that when I was
adding Subversive to Babel I definetely saw translations for it. (I also
provided our legacy translations for Subversive to Babel)
What could be the reason that there are no translations for Subversive,
maybe I missed smth.?
Re: No translations for Subversive [message #25383 is a reply to message #25178] Sat, 07 March 2009 06:54 Go to previous messageGo to next message
While you may find plenty of German speakers at Polarion, feel free to give
me a shout if you'd like it checked for the German translation.
I'm sure, both Hillary Clinton and Mr. Lavrov may not be very fond, if
someone accidentially wrote "Polaris" instead of "Polarion" for example ;-)
Werner
Re: No translations for Subversive [message #25424 is a reply to message #25178] Tue, 10 March 2009 07:35 Go to previous messageGo to next message
Can anybody from Babel Team answer it?
> Hello,
> site because Babel Language Pack Update Site for Ganymede doesn't work, as
> was already noted here in newsgroup).
> is present there but there are no translations for it, despite that when I
> was adding Subversive to Babel I definetely saw translations for it. (I
> also provided our legacy translations for Subversive to Babel)
Re: No translations for Subversive [message #25544 is a reply to message #25424] Sat, 14 March 2009 02:37 Go to previous messageGo to next message
Originally posted by: atoulme.intalio.com
There are currently no entries for Subversive. Please check your map
file is correct.
>> Hello,
Re: No translations for Subversive [message #25656 is a reply to message #25544] Mon, 16 March 2009 04:43 Go to previous messageGo to next message
Hello Antoine,
I see a post from Elena Nayashkova and it seems she has the same problem. So
I removed the second trunk definition, e.g. presviously I had entry:
plugin@org.eclipse.team.svn.core= SVN,trunk,http://dev.eclipse.org/svnroot/technology/org.ecli pse.subversive,,trunk/org.eclipse.team.svn.core
but now I changed it to:
plugin@org.eclipse.team.svn.core= SVN,trunk,http://dev.eclipse.org/svnroot/technology/org.ecli pse.subversive,,org.eclipse.team.svn.core
I hope it helps.
> There are currently no entries for Subversive. Please check your map file
> is correct.
Re: No translations for Subversive [message #25685 is a reply to message #25656] Tue, 17 March 2009 04:36 Go to previous messageGo to next message
It still doesn't work, so I fired a bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=268926
> Hello Antoine,
> So I removed the second trunk definition, e.g. presviously I had entry:
> I hope it helps.
>> is correct.
Re: No translations for Subversive [message #25829 is a reply to message #25685] Tue, 17 March 2009 07:44 Go to previous message
I replied there. Thanks for opening the bug.
Igor Burilo wrote:
> Hello,
>> Hello Antoine,
>> I hope it helps.
>>> is correct.
Re: No translations for Subversive [message #577241 is a reply to message #25178] Sat, 07 March 2009 06:54 Go to previous message
Werner
Re: No translations for Subversive [message #577263 is a reply to message #25178] Tue, 10 March 2009 07:35 Go to previous message
> Hello,
Re: No translations for Subversive [message #577337 is a reply to message #25424] Sat, 14 March 2009 02:37 Go to previous message
file is correct.
>> Hello,
Re: No translations for Subversive [message #577402 is a reply to message #25544] Mon, 16 March 2009 04:43 Go to previous message
Hello Antoine,
I hope it helps.
> is correct.
Re: No translations for Subversive [message #577420 is a reply to message #25656] Tue, 17 March 2009 04:36 Go to previous message
> Hello Antoine,
> I hope it helps.
>> is correct.
Re: No translations for Subversive [message #577446 is a reply to message #25685] Tue, 17 March 2009 07:44 Go to previous message
Igor Burilo wrote:
> Hello,
>> Hello Antoine,
>> I hope it helps.
>>> is correct.
Previous Topic:Babel Pseudo Translation Test:
Next Topic:How to share existing translations
Current Time: Fri Apr 18 20:17:00 EDT 2025
Powered by FUDForum. Page generated in 0.04736 seconds
