Problem starting BIRT 2.2 Engine [message #251122] |
Fri, 03 August 2007 15:27 |
Originally posted by: j.filimonova.spb.solidworks.ru
Hello!
I'm using BIRT 2.2 Engine API to render my report. Whole application is
running under JBoss 4.0.5. I try to start report engine from my JMX
MBean and I get a following error:
java.lang.NoSuchMethodError:
org.eclipse.birt.report.engine.api.EngineConfig.getLogger()L java/util/logging/Logger;
at
org.eclipse.birt.report.engine.api.impl.ReportEngine.intiali zeLogger(ReportEngine.java:108)
at
org.eclipse.birt.report.engine.api.impl.ReportEngine.<init>(ReportEngine.java:89)
at
org.eclipse.birt.report.engine.api.impl.ReportEngineFactory. createReportEngine(ReportEngineFactory.java:13)
at
com.swr.crm.as.report.ReportService.initializePlatform(Repor tService.java:189)
at
com.swr.crm.as.report.ReportService.startService(ReportServi ce.java:88)
at
Thanks in advance.
Re: Problem starting BIRT 2.2 Engine [message #251134 is a reply to message #251122] |
Fri, 03 August 2007 17:38 |
Originally posted by: jasonweathersby.alltel.net
Julia,
Are the versions of Java the same between the compiler and the JBoss
runtime?
Jason
Julia Filimonova wrote:
> Hello!
> at
> at
> at
> at
> at
> at
> Thanks in advance.
Re: Problem starting BIRT 2.2 Engine [message #251317 is a reply to message #251134] |
Mon, 06 August 2007 09:03 |
I've already resolved the problem..
Yes, Jason, the versions of Java were the same.
But I had to copy BIRT jar files to /jboss_directory/lib/endorsed/
I hope it will be useful for somebody.
Jason Weathersby wrote:
> Julia,
> runtime?
> Jason
>> Hello!
>> is running under JBoss 4.0.5. I try to start report engine from my JMX
>> at
>> at
>> at
>> at
>> at
>> at
>> Thanks in advance.
FUDForum. Page generated in 0.03618 seconds
