Home » Archived » BIRT » How to generate XLS or DOC by using REAPI
Re: How to generate XLS or DOC by using REAPI [message #250415 is a reply to message #250369] |
Mon, 30 July 2007 16:30 |
Originally posted by: jasonweathersby.alltel.net
Peng,
You just need to use the RenderOption class like this:
IReportDocument document = null;
//Open the report design
document
=engine.openReportDocument("output/resample/customers.rptdocument ");
IRenderOption options = new RenderOption();
options.setOutputFormat("xls");
options.setOutputFileName("output/resample/customers.xls");
IRenderTask task = engine.createRenderTask(document);
task.setRenderOption(options);
Jason
Peng wrote:
> does anyone know how to generate XLS or DOC format per Birt 2.2 Report
> Engine API ?
> i can generate PDF and HTML by using HTML- or PDFRenderOption
> programtically, but until now still don not find any example about how
> to use Birt 2.2 REAPI to generate XLS or DOC programmatically. Some
> prevoius discussions about it do not also give any ideas.
> thanks in advance
Re: How to generate XLS or DOC by using REAPI [message #250751 is a reply to message #250689] |
Wed, 01 August 2007 14:40 |
Can you post the entire stack trace.
Here is the complete sample I used:
Jason
import java.util.HashMap;
import java.util.logging.Level;
import org.eclipse.birt.core.framework.Platform;
import org.eclipse.birt.report.engine.api.EngineConfig;
import org.eclipse.birt.report.engine.api.EngineConstants;
import org.eclipse.birt.report.engine.api.EngineException;
import org.eclipse.birt.report.engine.api.HTMLActionHandler;
import org.eclipse.birt.report.engine.api.HTMLRenderOption;
import org.eclipse.birt.report.engine.api.PDFRenderOption;
import org.eclipse.birt.report.engine.api.HTMLServerImageHandler;
import org.eclipse.birt.report.engine.api.IReportEngine;
import org.eclipse.birt.report.engine.api.IReportEngineFactory;
import org.eclipse.birt.report.engine.api.IReportRunnable;
import org.eclipse.birt.report.engine.api.IReportDocument;
import org.eclipse.birt.report.engine.api.IRenderTask;
import org.eclipse.birt.report.engine.api.IRenderOption;
import org.eclipse.birt.report.engine.api.RenderOption;
import org.eclipse.birt.report.engine.api.IHTMLRenderOption;
import org.eclipse.birt.report.engine.api.IPDFRenderOption;
public class RenderTaskXLS {
public void runReport() throws EngineException
IReportEngine engine=null;
EngineConfig config = null;
try{
config = new EngineConfig( );
config.setBIRTHome("C:/birt/birt-runtime-2_2_0/birt-runtime-2_2_0/ReportEngine ");
config.setLogConfig(null, Level.FINE);
Platform.startup( config );
IReportEngineFactory factory = (IReportEngineFactory)
Platform.createFactoryObject(
IReportEngineFactory.EXTENSION_REPORT_ENGINE_FACTORY );
engine = factory.createReportEngine( config );
}catch( Exception ex){
ex.printStackTrace();
document =
task.render();
task.close();
engine.destroy();
Platform.shutdown();
System.out.println("Finished");
* @param args
try
RenderTaskXLS ex = new RenderTaskXLS( );
ex.runReport();
catch ( Exception e )
e.printStackTrace();
Said wrote:
> I tried the this example but I get the following error:
> at
> org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.o penReportDocument(ReportEngineHelper.java:395)
> at
> org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.o penReportDocument(ReportEngineHelper.java:342)
> at
> org.eclipse.birt.report.engine.api.impl.ReportEngine.openRep ortDocument(ReportEngine.java:423)
Re: How to generate XLS or DOC by using REAPI [message #250840 is a reply to message #250751] |
Wed, 01 August 2007 21:52 |
Originally posted by: xxxx.xxx.com
Jason, I could be able to generate a report output in XLS but I am
getting annoying log messages as follows in my dos window where I run
the Java class:
add data col = 0
Get Data = [0,0]
Get Data = [0,0]
add data col = 1
Get Data = [1,0]
Get Data = [1,0]
add data col = 2
Get Data = [2,0]
Get Data = [2,0]
Get Data = [0,0]
Get Data = [1,0]
Get Data = [2,0]
Get Data = [0,0]
Is there any way I can avoid this?
> Jason
> try{
> document =
> task.render();
> task.close();
> engine.destroy();
> * @param args
> public static void main(String[] args) {
> try
> ex.runReport();
> Said wrote:
>> Hi,
>> at
>> at
>> at
Re: How to generate XLS or DOC by using REAPI [message #250871 is a reply to message #250840] |
Thu, 02 August 2007 03:32 |
Can you set the log level to OFF?
Jason
> the Java class:
> add data col = 0
> Get Data = [0,0]
> Get Data = [0,0]
> add data col = 1
> Get Data = [1,0]
> Get Data = [1,0]
> add data col = 2
> Get Data = [2,0]
> Get Data = [2,0]
> Get Data = [0,0]
> Get Data = [1,0]
> Get Data = [2,0]
> Get Data = [0,0]
> Thanks
>> Jason
>> try{
>> document =
>> task.render();
>> task.close();
>> engine.destroy();
>> * @param args
>> try
>> ex.runReport();
>> Said wrote:
>>> Hi,
>>> at
>>> at
>>> at
Re: How to generate XLS or DOC by using REAPI [message #252545 is a reply to message #250840] |
Wed, 15 August 2007 15:26 |
Jason, I couldnt stop (with log level OFF) displaying these messaged
from printing. One thing I am noticing about these messages that they
dont look like (message format) they are from the logger but from a
debug statement like System.out.println().
Is there any possibility that any developer could ve left that debug
statement in there and forgot to take it out?
> the Java class:
> add data col = 0
> Get Data = [0,0]
> Get Data = [0,0]
> add data col = 1
> Get Data = [1,0]
> Get Data = [1,0]
> add data col = 2
> Get Data = [2,0]
> Get Data = [2,0]
> Get Data = [0,0]
> Get Data = [1,0]
> Get Data = [2,0]
> Get Data = [0,0]
> Thanks
>> Jason
>> try{
>> document =
>> task.render();
>> task.close();
>> engine.destroy();
>> * @param args
>> try
>> ex.runReport();
>> Said wrote:
>>> Hi,
>>> at
>>> at
>>> at
Re: How to generate XLS or DOC by using REAPI [message #252574 is a reply to message #252545] |
Wed, 15 August 2007 18:45 |
Der Spunk Messages: 58 Registered: July 2009 |
Member |
Please have a look at bug
https://bugs.eclipse.org/bugs/show_bug.cgi?id=198843
It is fixed in 2.2.1.
Spunk
"Kris" <xxxx@xxx.com> schrieb im Newsbeitrag
news:f9v5vh$rt2$1@build.eclipse.org...
> Jason, I couldnt stop (with log level OFF) displaying these messaged from
> printing. One thing I am noticing about these messages that they dont look
> like (message format) they are from the logger but from a debug statement
> Thanks
>> getting annoying log messages as follows in my dos window where I run the
>> Java class:
>> add data col = 0
>> Get Data = [0,0]
>> Get Data = [0,0]
>> add data col = 1
>> Get Data = [1,0]
>> Get Data = [1,0]
>> add data col = 2
>> Get Data = [2,0]
>> Get Data = [2,0]
>> Get Data = [0,0]
>> Get Data = [1,0]
>> Get Data = [2,0]
>> Get Data = [0,0]
>> Thanks
>>> Jason
>>> try{
>>> document =
>>> task.render();
>>> task.close();
>>> engine.destroy();
>>> * @param args
>>> try
>>> ex.runReport();
>>> Said wrote:
>>>> Hi,
>>>> at
>>>> at
>>>> at
Current Time: Mon Jul 22 02:31:07 GMT 2024
Powered by FUDForum. Page generated in 0.04958 seconds
