Iam not getting Team->synchronize option [message #250116] |
Mon, 07 June 2004 14:39 |
Originally posted by: ssequeira.icope.com
Hi,all.Why iam not getting Team->synchronize option on context menu while
selecting the resorce in navigator view.
Also synchronize toolbar button is disabled.Why is it so.I have setup
the cvs repository location and iam getting whatever contents r there in
cvs.Also i simply want to modify a file and then take latest for testing
purpose.
On selecting a file iam not getting options for checkout/checkin.Only
for folders option such as "checkout as project" is coming.
Pls do help me.
steven
Re: Iam not getting Team->synchronize option [message #250292 is a reply to message #250116] |
Mon, 07 June 2004 21:59 |
> purpose.
> Pls do help me.
It sounds as if the Project that you are trying it on might not be
associated with CVS. If you right-click on the Project name and choose
the Team pop-up menu, what choices are listed there?
Eric
Re: Iam not getting Team->synchronize option [message #250336 is a reply to message #250292] |
Tue, 08 June 2004 04:39 |
Hi.if i select project and then select team i get options as:apply
patch,share project.Only these 2 options.Is it that first i have to share
project,then synchronze view will appear.
pls hlp in this regard
steven
> > purpose.
> > Pls do help me.
> Eric
For existing files in cvs,how do i update/commit [message #250367 is a reply to message #250336] |
Tue, 08 June 2004 08:01 |
Hi,when i create a new project and then share it using Team,i got the
synchronize view.Now i get commit options.This is solved.
But wat abt existing files in cvs.These files will appear only in cvs
prspective.How do i checkout the existing ones.No options iam able to get.
In navigator view iam getng the prjcts that r in workspace not cvs.For
existing files in cvs view if i right click on file i get compare
with,replace with etc.
I want to modify a file in my local workspace and then i will take
latest,just for testing purpose.
Pls help in this regard.
Steven
Re: For existing files in cvs,how do i update/commit [message #250473 is a reply to message #250383] |
Tue, 08 June 2004 13:46 |
Jens wrote:
> Does your project already exist in the repository?
> Or is it new?
> ok ... try this:
> (1) Window > Show view > Other > CVS > CVS Repositories
> (2) Then select your module you like to check out ...
> Try this short tutorial, how to work with Eclipse (I know it is written
> for the WSAD, but eclipse is similar):
> http://www.redbooks.ibm.com/redbooks/pdfs/sg246957.pdf
Also open the Eclipse Help and look at the Getting Started sections.
There is a tutorial for working with Eclipse and CVS that would have
answered all of your questions.
Eric
FUDForum. Page generated in 0.06428 seconds
