Re: IJavaElement from ITextSelection [message #249864 is a reply to message #249835] |
Tue, 27 November 2007 23:19 |
Jeffrey K Czyz Messages: 6 Registered: July 2009 |
>>>> Hello all,
>>>> Is there a simple way of obtaining the IJavaElement associated with
>>>> the currently selected text? The only way I can accomplish this is
>>>> using an internal class, which I would like to avoid:
>>>> if (selection instanceof ITextSelection) {
>>>> ITextSelection textSelection = (ITextSelection) selection;
>>>> IWorkbenchPage activePage =
>>>> PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage();
>>>> if (activePage != null) {
>>>> IEditorPart editor = activePage.getActiveEditor();
>>>> if (editor instanceof CompilationUnitEditor) {
>>>> CompilationUnitEditor unitEditor = (CompilationUnitEditor)
>>>> editor;
>>>> IJavaElement element = (IJavaElement)
>>>> unitEditor.getViewPartInput();
>>> I'm not sure about which CompilationUnitEditor you're talking about
>>> but the one I know does not have a getViewPartInput() method. Anyway,
>>> what you should use ist:
>>> typeRoot=
>>> org.eclipse.jdt.ui.JavaUI.getEditorInputTypeRoot(IEditorInpu t)
>>> typeRoot.codeSelect(selectionOffset, selectionLength)
>>> Dani
>> Hi Dani,
>> Thanks for the reply. CompilationUnitEditor is a class in the
>> internal package org.eclipse.jdt.internal.ui.javaeditor.
> I know that. But this one does not have a getViewPartInput() method.
It is located in the super class (JavaEditor).
>> I wanted to avoid using it.
>> The example code you gave uses
>> JavaUI.getEditorInputTypeRoot(IEditorInput), which is new in Eclipse
>> 3.4. Is there a different way of accomplishing this using Eclipse 3.3?
> org.eclipse.jdt.ui.JavaUI.getEditorInputJavaElement(IEditorI nput)
> Dani
Thanks, that did the trick.
Jeff
>> Thanks,
>> Jeff
>>>> In the above code, CompilationUnitEditor is internal. Any help
>>>> would be appreciated.
>>>> Jeff
FUDForum. Page generated in 0.04142 seconds
