[zest] Network with pre-defined coordinates [message #247595] |
Wed, 04 March 2009 15:12 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
is it possible to position nodes with Zest based on pre-defined
coordinates?
I have objects which represents physical locations and which have a name,
a longitude and a latitude. Can I place these locations via zest on their
positions?
If yes, can you point me to a small example on how to do this?
Best regards, Lars
Re: [zest] Network with pre-defined coordinates [message #248238 is a reply to message #247620] |
Fri, 10 April 2009 06:25 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: irbull.cs.uvic.ca
Thanks Lars,
note, a user can likely still drag a node. Is this a problem for you?
cheers,
ian
Lars Vogel wrote:
> after removing the automatic layout manager I can control the points
> there the nodes are placed. My question is therefore solved.
> Best regards, Lars
Re: [zest] Network with pre-defined coordinates [message #249250 is a reply to message #248238] |
Thu, 11 June 2009 21:58 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Hi Ian,
Thank you for the answer. No dragging a node is actually I very nice
feature.
Best regards, Lars
Ian Bull wrote:
> Thanks Lars,
> cheers,
> ian
> Lars Vogel wrote:
>> Hi,
>> Best regards, Lars
FUDForum. Page generated in 0.03993 seconds
