Eclipse installation problem [message #247491] |
Sat, 02 February 2008 20:23 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: priyan_67.yahoo.co.in
I am new to eclipse. My system had eclipse earlier(on fedora 6). I
uninstalled it and installed it again using YUM. Installation completed
successfully. But I am not able to run the eclipse now. When I run it
exits without opening. And it shows the error message that
" An error has occurred. See the log file
/root/workspace/.metadata/.log. "
The first few lines of the log file is below.
!SESSION 2008-02-03 04:34:27.816
eclipse.buildId=M20070212-1330
java.fullversion=GNU libgcj 4.1.2 20070626 (Red Hat 4.1.2-13)
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Command-line arguments: -os linux -ws gtk -arch x86
!ENTRY org.eclipse.update.configurator 2008-02-03 04:34:28.989
!MESSAGE Could not install bundle plugins/org.eclipse.pde.build/ Bundle
"org.eclipse.pde.build" version "3.2.1.r321_v20060823" has already been
installed from: update@plugins/org.eclipse.pde.build_3.2.1.r321_v20060823/
!ENTRY org.eclipse.core.runtime 2008-02-03 04:34:30.557
!MESSAGE Product org.eclipse.sdk.ide could not be found.
!ENTRY org.eclipse.osgi 4 0 2008-02-03 04:34:30.561
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: No application id has been found.
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(or g.eclipse.core.runtime_3.2.0.v20060603.jar.so)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(org.eclipse.osgi_3.2.2.R32x_v20070118.jar.so )
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(org.eclipse.osgi_3.2.2.R32x_v20070118.jar.so)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(org.ecli pse.osgi_3.2.2.R32x_v20070118.jar.so)
at
at java.lang.reflect.Method.invoke(libgcj.so.7rh)
at org.eclipse.core.launcher.Main.invokeFramework(startup.jar.s o)
at org.eclipse.core.launcher.Main.basicRun(startup.jar.so)
at org.eclipse.core.launcher.Main.run(startup.jar.so)
at org.eclipse.core.launcher.Main.main(startup.jar.so)
!ENTRY org.eclipse.osgi 2 0 2008-02-03 04:34:30.821
!MESSAGE One or more bundles are not resolved because the following root
constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2008-02-03 04:34:30.821
!MESSAGE Bundle
update@plugins/org.eclipse.team.cvs.ssh2_3.2.1.M20061205.jar was not
resolved.
!SUBENTRY 2 org.eclipse.team.cvs.ssh2 2 0 2008-02-03 04:34:30.822
!MESSAGE Missing required bundle org.eclipse.swt_[3.2.0,4.0.0).
!SUBENTRY 1 org.eclipse.osgi 2 0 2008-02-03 04:34:30.822
!MESSAGE Bundle
update@plugins/org.eclipse.draw2d_3.2.1.R32_Maintenance.jar was not
resolved.
!SUBENTRY 2 org.eclipse.draw2d 2 0 2008-02-03 04:34:30.822
!MESSAGE Bundle
update@plugins/org.eclipse.jface.text_3.2.2.r322_v20070104.jar was not
resolved.
!SUBENTRY 2 org.eclipse.jface.text 2 0 2008-02-03 04:34:30.822
!MESSAGE Bundle update@plugins/org.eclipse.ui_3.2.1.M20061108.jar was not
resolved.
!SUBENTRY 2 org.eclipse.ui 2 0 2008-02-03 04:34:30.822
!MESSAGE Bundle
update@plugins/org.eclipse.ui.workbench_3.2.2.M20070119-0800.jar was not
resolved.
!SUBENTRY 2 org.eclipse.ui.workbench 2 0 2008-02-03 04:34:30.822
!MESSAGE Bundle update@plugins/net.sourceforge.phpeclipse_1.1.8/ was not
resolved.
!SUBENTRY 2 net.sourceforge.phpeclipse 2 0 2008-02-03 04:34:30.822
!MESSAGE Missing required bundle org.eclipse.swt_0.0.0.
!MESSAGE Bundle update@plugins/net.sourceforge.phpeclipse.phphelp_1.1.8/
was not resolved.
!SUBENTRY 2 net.sourceforge.phpeclipse.phphelp 2 0 2008-02-03 04:34:30.822
!MESSAGE Bundle update@plugins/org.eclipse.jface_3.2.2.M20061214-1200.jar
was not resolved.
!SUBENTRY 2 org.eclipse.jface 2 0 2008-02-03 04:34:30.822
!ENTRY org.eclipse.osgi 2 0 2008-02-03 04:34:30.871
!MESSAGE The following is a complete list of bundles which are not
resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2008-02-03 04:34:30.871
!MESSAGE Bundle
update@.. /../lib/eclipse/plugins/org.eclipse.platform.doc.isv_3.2.2.R 32x_v20070115.jar
was not resolved.
!SUBENTRY 2 org.eclipse.platform.doc.isv 2 0 2008-02-03 04:34:30.871
!MESSAGE Missing required bundle org.eclipse.ui_[3.2.0,4.0.0).
!MESSAGE Bundle
update@.. /../lib/eclipse/plugins/org.eclipse.sdk_3.2.2.r322_v20070212 /
[15] was not resolved.
!SUBENTRY 2 org.eclipse.sdk 2 0 2008-02-03 04:34:30.871
!MESSAGE Missing required bundle org.eclipse.help.ui_[3.2.0,4.0.0).
I want to use eclipse from now on because of the wide variety of features
it has. But because of this issue I am not able to start with. Can someone
please help me in resolving this issue quickly.
Priyan.
Re: Eclipse installation problem [message #247499 is a reply to message #247491] |
Sat, 02 February 2008 21:12 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Mark Dexter![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=dextercowley%40gmail.com) Messages: 324 Registered: July 2009 |
Priyan wrote:
> Bundle "org.eclipse.pde.build" version "3.2.1.r321_v20060823" has
> already been installed from:
> !STACK 1
> at
> at
> at
> at
> at
> !MESSAGE Bundle
> resolved.
> !MESSAGE Bundle
> resolved.
> !MESSAGE Bundle
> resolved.
> not resolved.
> !MESSAGE Bundle
> resolved.
> resolved.
> was not resolved.
> !MESSAGE Bundle
> update@plugins/org.eclipse.jface_3.2.2.M20061214-1200.jar was not resolved.
> !MESSAGE Bundle
> was not resolved.
> !MESSAGE Bundle
> features it has. But because of this issue I am not able to start with.
> Can someone please help me in resolving this issue quickly.
> Priyan.
Hi Priyan. It looks like you're trying to run Eclipse with the GNU Java,
which I think doesn't work. Take a look at the link below and see if
that helps.
http://wiki.eclipse.org/IRC_FAQ#I_just_installed_Eclipse_on_ Linux.2C_but_it_does_not_start._What_is_the_problem.3F
Mark
Re: Eclipse installation problem [message #247534 is a reply to message #247499] |
Sun, 03 February 2008 16:01 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hi Mark,
Thanks for your reply.
I want to work on "C" on eclipse. So in that case can I avoid/disable java
in the current eclipse setup and start running eclipse successfully? If
that is possible then can I need to remove jdk? or any other changes? I
tried installing jdk and jre from sun-java. But this didn't help. Please
help me on this regard.
Priyan.
Re: Eclipse installation problem [message #247649 is a reply to message #247574] |
Mon, 04 February 2008 17:25 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hi Mark,
Thanks for your support...
I have tried what you have mentioned.
I have installed "jre-6u4-linux-i586-rpm.bin" and
"jdk-6u4-linux-i586-rpm.bin"
(downloaded. size is 66488684 and 19125837 bytes) and used this to start
eclipse like below.
1) $ eclipse -vm /usr/java/jre1.6.0_04/bin/java (Try to start and gives
error)
(or)
2) $ eclipse -vm /usr/java/jdk1.6.0_04/bin/java (Try to start and gives
error)
(or)
3) $ eclipse -vm /usr/java/jdk1.6.0_04/bin/javaws (not executing at all)
After this the java executable is taken from the installed one(as per the
log).
For the 2)nd run (eclipse -vm /usr/java/jdk1.6.0_04/bin/java) I have given
the starting lines of the log below.
Please tell me if I have done anything wrong.
Also I don't know why this error message
"!MESSAGE Could not install bundle plugins/org.eclipse.pde.build/"
"!MESSAGE Product org.eclipse.sdk.ide could not be found"
is appearing. Does it indicate that anything wrong in the installation?
Kindly help me on this regard.
Priyan.
!SESSION 2008-02-04 22:42:58.535
java.version=1.6.0_04
!ENTRY org.eclipse.update.configurator 2008-02-04 22:42:59.572
!ENTRY org.eclipse.core.runtime 2008-02-04 22:43:00.692
!ENTRY org.eclipse.osgi 4 0 2008-02-04 22:43:00.716
!STACK 1
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:56)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at
at
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
!ENTRY org.eclipse.osgi 2 0 2008-02-04 22:43:00.773
!SUBENTRY 1 org.eclipse.osgi 2 0 2008-02-04 22:43:00.773
Re: Eclipse installation problem [message #247664 is a reply to message #247649] |
Mon, 04 February 2008 17:57 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Priyan wrote:
> Hi Mark, Thanks for your support...
> eclipse like below.
> error)
> (or)
> error)
> (or)
> the log).
> given the starting lines of the log below.
> Also I don't know why this error message "!MESSAGE Could not install
> bundle plugins/org.eclipse.pde.build/" "!MESSAGE Product
> org.eclipse.sdk.ide could not be found" is appearing. Does it indicate
> Priyan.
> !STACK 1
> at
> at
> at
> at
> at
> at
> at
> at java.lang.reflect.Method.invoke(Method.java:597)
Hi Priyan. I'm sorry you're having these problems. It sounds like you
have installed Eclipse from RPM distributions, and it looks to me like
your Eclipse installation is not correct.
I would suggest downloading the Eclipse directly from Eclipse.org and
installing from the download. All you need to do to install it is unzip
the download somewhere in Linux. There are instructions on the Wiki, I
think.
Be sure to do this in a different directory from where your current
Eclipse is installed. If you do this, and use the same command line, I
think it should work. Otherwise, we'll have to get help from someone
that knows a lot more about this than I do. Hang in there. Mark
FUDForum. Page generated in 0.08929 seconds
