Home » Newcomers » Newcomers » Include SWT/JavaDoc, Export jar file of project
Re: Include SWT/JavaDoc, Export jar file of project [message #246226 is a reply to message #246021] |
Mon, 21 January 2008 23:24 |
Markus Fischer Messages: 6 Registered: July 2009 |
kiril mitov wrote:
> Right Click on the Project->Build Path->Configure Build Path->Go to the
> Libraries Tab->Add Variable->Select ECLIPSE_HOME->Extend...->Chose
> plugins/org.eclipse.swt*.jar and click ok. This will add the
> org.eclipse.swt jars from you eclipse installation to the build path.
I'm failing to achive this, I don't have ECLIPSE_HOME in there, just JRE_LIB,
JRE_SRC, JRE_SRCROOT and JUNIT_HOME (though I didn't set the myself in any way).
> In my case I have org.eclipse.swt, org.eclipse.swt.gkt.linux.x86 and
> org.eclipse.swt.gtk.linux.x86.source.
I've only the files org.eclipse.swt.win32.win32.x86_3.3.2.v3347a.jar (~2MB)
and org.eclipse.swt_3.3.2.v3347.jar (16kb) there.
> The other way is simply to add the above libraries not through
> EClIPSE_HOME variable, but as external jars.
I tried this, in fact I've a single swt.jar already attached to the project to
even be able to build this.
> I am not sure if eclipse-java-europa-fall2-win32.zip contains the source
> of swt.
I think that's the real source of my confusion :) Where do I get the source of
SWT? I managed to get the binary from http://www.eclipse.org/swt/ but I can't
see the sources linked. And I can't figure out where to download the JavaDOC
and link it within eclipse :-/
>> the JavaDoc for SWT locally and where to I have to put it so I can
>> access it from within PHP?
> Not sure about this one. What do you mean by access it from within PHP?
Sorry, my bad, I tried to do many things at the same time :) PHP should read
"Eclipse". It's the question, once I've the JavaDoc API of SWT (which I don't
know yet where to get from), where to put it it so I can use it from within
Eclipse.
Or would I just need the sources and get the complete documentation automatically?
thank you,
- Markus
Re: Include SWT/JavaDoc, Export jar file of project [message #246633 is a reply to message #246226] |
Thu, 24 January 2008 08:03 |
kiril mitov Messages: 69 Registered: July 2009 |
Member |
Hi Markus,
Go to eclipse.org->downloads->eclipse Classics 3.3.1.1 All
Versions->3.3.1.1.
You should then be at
http://download.eclipse.org/eclipse/downloads/drops/R-3.3.1. 1-200710231652/index.php
Scroll down the page and see the "SWT Binary and Source" section. This
is where you can download the source of SWT.
If you would like to see the JavaDoc of SWT open your eclipse and go to
Help->Help Contents->Platform Plugin Developer Guide->Reference->API
Reference. There you should see the org.eclipse.swt packages and classes.
Best Regards,
Kiril
Markus Fischer wrote:
> JRE_LIB, JRE_SRC, JRE_SRCROOT and JUNIT_HOME (though I didn't set the
> myself in any way).
> (~2MB) and org.eclipse.swt_3.3.2.v3347.jar (16kb) there.
> project to even be able to build this.
>> of swt.
> source of SWT? I managed to get the binary from
> http://www.eclipse.org/swt/ but I can't see the sources linked. And I
> can't figure out where to download the JavaDOC and link it within
> eclipse :-/
> read "Eclipse". It's the question, once I've the JavaDoc API of SWT
> (which I don't know yet where to get from), where to put it it so I can
> use it from within Eclipse.
> automatically?
> thank you,
> - Markus
Current Time: Sun Oct 06 14:19:42 GMT 2024
Powered by FUDForum. Page generated in 0.09453 seconds
