Home » Eclipse Projects » GEF » Convert IFigure to Vector PDF Friendly Format (ie EPS, PS)
Convert IFigure to Vector PDF Friendly Format (ie EPS, PS) [message #245029] Wed, 20 August 2008 05:33 Go to next message
I have a figure, what is the best way (other than svg) to convert that to
a vector format that can be easily put into a pdf?
thanks
Re: Convert IFigure to Vector PDF Friendly Format (ie EPS, PS) [message #245058 is a reply to message #245029] Thu, 21 August 2008 00:20 Go to previous messageGo to next message
GMF uses Apache Batik library to export diagrams to PDF format. I think,
however, that diagram is really exported to SVG and then from SVG to PDF.
Alex
Re: Convert IFigure to Vector PDF Friendly Format (ie EPS, PS) [message #245063 is a reply to message #245058] Thu, 21 August 2008 03:29 Go to previous messageGo to next message
Even that way would be ok for me if at the end of all the conversion the
result is not a bitmap. But that is not the case is it?
Re: Convert IFigure to Vector PDF Friendly Format (ie EPS, PS) [message #245072 is a reply to message #245063] Thu, 21 August 2008 12:16 Go to previous messageGo to next message
It' not a bitmap at the end as far as I know. Look for CopyToImasgeUtil
class in GMF - it's a starting point for your investigation. You can try
exporting example editor diagrams to (geoshape, logic) PDF images.
Alex
Re: Convert IFigure to Vector PDF Friendly Format (ie EPS, PS) [message #245115 is a reply to message #245072] Fri, 22 August 2008 09:23 Go to previous message
alrighty thanks.
Previous Topic:Problem in positioning label on connection
Next Topic:Bad appearance of PaletteGroups since Ganymede
Current Time: Mon Mar 31 14:20:03 EDT 2025
Powered by FUDForum. Page generated in 0.03988 seconds
