Defect in flow analysis ? [message #244615] |
Mon, 18 June 2007 07:28 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: none.domain.invalid
Should i report a bug for this :
public class TestUndefined {
Object throwRuntimeException() {
throw new RuntimeException();
void test1() {
Object o;
try {
o = throwRuntimeException();
} finally {
// The local variable o may not have been initialized
o.hashCode();
void test2() {
Object o;
try {
} finally {
// nothing reported
o.hashCode();
Re: Defect in flow analysis ? [message #244624 is a reply to message #244615] |
Mon, 18 June 2007 10:27 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
If in test2, an exception is thrown, o.hashCode() won't be reached,
right? In other words, if o.hashCode is call in test2(), then it must
have been initialized properly.
> void test1() {
> Object o;
> try {
> } finally {
> o.hashCode();
> void test2() {
> Object o;
> try {
> } finally {
> // nothing reported
> o.hashCode();
Re: Defect in flow analysis ? [message #244628 is a reply to message #244624] |
Mon, 18 June 2007 10:46 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Thanks of the explanation. With a catch block i get an error, so it's ok.
FUDForum. Page generated in 0.04180 seconds
