Re: Firing JS event at end of RunTask? [message #244014 is a reply to message #243973] |
Thu, 21 June 2007 16:17 |
Originally posted by: jasonweathersby.alltel.net
Olaf,
The afterFactory is the correct location. How are you determining that
it is not being called.
If you use runandrender vs a run and then render the events are called
slightly different. Also initialize is always called for each phase.
Jason
Olaf Lenzmann wrote:
> Hi all,
> I am running and rendering reports in separate tasks and want to write
> some JS-code that sets a global persistent variable after running the
> report, before the document is saved (based on what other JS-handlers
> have gathered in onCreate() of their items). What would be the right
> hook to use? afterFactory() doesn't seem to get called by the RunTask
> and of the report item events, onCreate() is too early and onRender() is
> only called by the RenderTask.
> TIA,
> Olaf
Re: Firing JS event at end of RunTask? [message #244019 is a reply to message #244014] |
Thu, 21 June 2007 16:30 |
Olaf,
There may be an issue with accessing variables from onRender.
I just logged a bugzilla entry.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=193782
Jason
Jason Weathersby wrote:
> Olaf,
> Jason
>> Hi all,
>> is only called by the RenderTask.
>> TIA,
>> Olaf
Re: Firing JS event at end of RunTask? [message #244157 is a reply to message #244019] |
Fri, 22 June 2007 06:40 |
No real name Messages: 23 Registered: July 2009 |
Jason,
I have in my afterFactory()
reportContext.setPersistentGlobalVariable( "rating", new
Packages.java.lang.Long(3) )
and looking at the file that the run task creates, I cannot find the
variable stored.
The workaround I use now is to put the code into beforeClose() of my main
dataset and with this change, the global variable appears in the report
document.
Olaf
> Olaf,
> Jason
>> Olaf,
>> Jason
>>> Hi all,
>>> TIA,
>>> Olaf
Re: Firing JS event at end of RunTask? [message #244346 is a reply to message #244157] |
Fri, 22 June 2007 15:57 |
Olaf,
According to the bugzilla entry the report document is closed before the
afterfactory event. This is why it is not showing up.
Jason
> Jason,
> variable stored.
> main dataset and with this change, the global variable appears in the
> report document.
> Olaf
>> Olaf,
>> Jason
>>> Olaf,
>>> that it is not being called.
>>> called slightly different. Also initialize is always called for each
>>> phase.
>>> Jason
>>>> Hi all,
>>>> write some JS-code that sets a global persistent variable after
>>>> running the report, before the document is saved (based on what
>>>> other JS-handlers have gathered in onCreate() of their items). What
>>>> would be the right hook to use? afterFactory() doesn't seem to get
>>>> called by the RunTask and of the report item events, onCreate() is
>>>> too early and onRender() is only called by the RenderTask.
>>>> TIA,
>>>> Olaf
Re: Firing JS event at end of RunTask? [message #244531 is a reply to message #244346] |
Mon, 25 June 2007 06:19 |
Jason,
I had not seen that in the entry - thanks.
Olaf
On 22.06.2007 17:57:50, Jason Weathersby wrote:
> Olaf,
> Jason
>> Jason,
>> variable stored.
>> report document.
>> Olaf
>>> Olaf,
>>> Jason
>>>> Olaf,
>>>> phase.
>>>> Jason
>>>>> Hi all,
>>>>> TIA,
>>>>> Olaf
FUDForum. Page generated in 0.04751 seconds
