Launch debugger problem [message #243041] |
Fri, 14 December 2007 10:22 |
Originally posted by: john.pedersen.gmail.com
I have a new installation of Eclipse 3.3.1.1 Europa version.
Trying to use the debugger, I just get this:
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner at localhost:50095
Thread [main] (Suspended (exception ClassNotFoundException))
ClassLoader.findBootstrapClass(String) line: not available [native
method]
Launcher$ExtClassLoader(ClassLoader).findBootstrapClass0(Str ing) line:
not available
Launcher$ExtClassLoader(ClassLoader).loadClass(String, boolean) line:
not available
Launcher$AppClassLoader(ClassLoader).loadClass(String, boolean) line:
not available
Launcher$AppClassLoader.loadClass(String, boolean) line: not available
Launcher$AppClassLoader(ClassLoader).loadClass(String) line: not
available
Launcher$AppClassLoader(ClassLoader).loadClassInternal(Strin g) line: not
available
I have poked around with my classpath settings, but can't owrk out what's
wrong.
Can someone help please?
John
Re: Launch debugger problem [message #243085 is a reply to message #243041] |
Fri, 14 December 2007 14:38 |
Originally posted by: eclipse-news.rizzoweb.com
John Pedersen wrote:
> localhost:50095
> [native method]
> line: not available
> line: not available
> line: not available
> available
> available
> line: not available
> what's wrong.
Try deleting the launch configuration for that JUnit and then let
Eclipse re-create it by right-clicking on the test class (or its
project) and choosing Run As...
Hope this helps,
Eric
Re: Launch debugger problem [message #243095 is a reply to message #243085] |
Fri, 14 December 2007 15:12 |
Thanks for the suggestion.
I have just tried that, but got the same result.
I have some other tests, that used to work with the debugger with a
previous installation of Eclipse, but they don't work now.
JUnit is there in the classpath - something missing that I can't see.
Re: Launch debugger problem [message #243188 is a reply to message #243140] |
Fri, 14 December 2007 20:38 |
Hi Mark,
It's limited to debugger sessions. Whether it is JUnit or a nonJUnit
program makes no difference. I can't do Debug As, and have tried deleting
configurations in the Debug Dialog, so that Eclipse will generate a new
configuration, but that doesn't help. I can do Run As just fine.
Always the same error message.
John
New_configuration [Java Application]
com.starfriend.utils.Test at localhost:51751
method]
not available
not available
not available
available
not available
C:\Program Files\Java\jre1.6.0_03\bin\javaw.exe (14 Dec 2007 20:37:36)
FUDForum. Page generated in 0.09540 seconds
