Home » Language IDEs » Java Development Tools (JDT) » Debugging java code invoked from a C++ application
Debugging java code invoked from a C++ application [message #242756] Wed, 11 April 2007 15:16 Go to next message
I have a C++ application that invokes Java code when the user performs a
certain action. Is there a way for me to debug such java code? E.g. can I
attach a jvm to jdt, just like attaching a process to C++ debugger when
debugging jni code?
Connie
Re: Debugging java code invoked from a C++ application [message #242802 is a reply to message #242756] Thu, 12 April 2007 18:29 Go to previous messageGo to next message
Originally posted by: eclipse5.rizzoweb.com
Connie wrote:
> I attach a jvm to jdt, just like attaching a process to C++ debugger
> when debugging jni code?
It is not clear what is happening. For example, how does C++ code invoke
Java code?
You can certainly attach the JDT debugger to any JVM, assuming you can
control the start-up parameters of that JVM to specify the appropriate
debug params (a JVM has to be started with specific params in order to
enable debug mode). The Eclipse Help has lots of information related to
this, which is called "Remote Debugging" (even when the JVM is on the
same machine).
But the question remains for you, how is the C++ app launching Java?
Hope this helps,
Eric
Re: Debugging java code invoked from a C++ application [message #242833 is a reply to message #242802] Thu, 12 April 2007 22:45 Go to previous message
Eric Rizzo wrote:
> Connie wrote:
>> Hi,
> Java code?
> same machine).
> Hope this helps,
> Eric
Thanks Eric for your help! I am now able to debug my Java code!
I started a JVM in my C++ code by specifying the necessary class paths,
and used CallStaticVoidMethod to make a call to the Java code. I also
added the following lines to my C++ code to enable debug mode:
options[3].optionString = "-Xdebug";
options[4].optionString =
" -Xrunjdwp:transport=dt_socket,address=8000,server=y,suspend= n ";
Then I created a remote launch configuration, specified localhost as the
host and 8000 as the port, and ran it in debug mode.
Connie
Previous Topic:Sample JDT code -
Next Topic:Recommended way to use AST to do template-based code gen?
Current Time: Sat Oct 25 00:33:56 EDT 2025
Powered by FUDForum. Page generated in 0.04051 seconds
