Home » Eclipse Projects » Eclipse Platform » Ant input task blocks Console
Ant input task blocks Console [message #239005] Wed, 05 May 2004 20:03 Go to next message
Kenneth Costilow is currently offline Kenneth CostilowFriend
Eclipse 3.0M8
Ant 1.6.1
Windows XP
(See bug #45854)
It appears that any Ant <input> task blocks the Eclipse Console. I have
tried writing my own InputHandler but all I can do is simplify the existing
one (still using System.in), which always continues to block.
Does anybody have a workaround for this ? Maybe there is a specific Eclipse
InputHandler implementation for Console that I need to specify to Ant
(using -inputhandler) ?
Ken
Re: Ant input task blocks Console [message #239028 is a reply to message #239005] Wed, 05 May 2004 21:48 Go to previous messageGo to next message
Darin Swanson is currently offline Darin SwansonFriend
I believe you meant to reference
https://bugs.eclipse.org/bugs/show_bug.cgi?id=45484
I have not had the time to finish up an Eclipse input handler for this case
(and it is not looking good for 3.0)..I will try to get some more time to
this.
I will post to the bug report where I am at currently so that possible
others could help finish (I will try to do this tomorrow).
Can you run your build in the same VM as Eclispe for now where the input
does work?
Darins
"Ken Costilow" <Ken.Costilow@delta.com> wrote in message
news:c7bh8v$2u3$2@eclipse.org...
> Eclipse 3.0M8
> Ant 1.6.1
> Windows XP
> (See bug #45854)
existing
Eclipse
> Thanks
> Ken
Re: Ant input task blocks Console [message #239048 is a reply to message #239028] Wed, 05 May 2004 21:11 Go to previous messageGo to next message
Yes that's the correct number; sorry about that.
I'm glad to know that there isn't some simple fix that I overlooked (for a
change) !
Regarding the "same VM as Eclipse" - do you mean to uncheck the Ant "Launch
in Background" box on the Ant External Tools Launcher Common page ? If so ,
that seems to have no effect.
If not, please advise.
Thanks for the prompt response.
kc
"Darin Swanson" <Darin_Swanson@us.ibm.com> wrote in message
news:c7bjhn$5tq$1@eclipse.org...
case
> this.
> does work?
> Darins
> > Eclipse 3.0M8
> > Ant 1.6.1
> > Windows XP
> > (See bug #45854)
> existing
> Eclipse
> > Thanks
> > Ken
Re: Ant input task blocks Console [message #239073 is a reply to message #239048] Wed, 05 May 2004 22:49 Go to previous message
Sorry should have provided exact instructions:
Go to the JRE page for your Ant Launch Configuration.
Change it to run in the Same JRE as Eclipse
Input handling works with the UI input handler.
HTH
Darins
news:c7bkts$7vs$1@eclipse.org...
> change) !
"Launch
> kc
> case
to
> > this.
> > does work?
> > Darins
> > > Eclipse 3.0M8
> > > Ant 1.6.1
> > > Windows XP
> > > (See bug #45854)
have
> > existing
> > Eclipse
> > > Thanks
> > > Ken
Re: Ant input task blocks Console [message #239078 is a reply to message #239073] Wed, 05 May 2004 22:15 Go to previous message
Duh - didn't even notice that. Naturally that fixed it. That's exactly the
kind of workaround I was looking for.
kc
news:c7bn4e$aql$1@eclipse.org...
> HTH
> Darins
a
> > change) !
> "Launch
so
> > kc
> > case
> to
> > > this.
input
> > > does work?
> > > Darins
> > > > Eclipse 3.0M8
> > > > Ant 1.6.1
> > > > Windows XP
> > > > (See bug #45854)
> have
> > > existing
> > > Eclipse
Ant
> > > > Thanks
> > > > Ken
Previous Topic:Problem sharing project for first time
Next Topic:Getting view references from an open perspective
Current Time: Wed Jan 15 12:34:32 GMT 2025
Powered by FUDForum. Page generated in 0.03181 seconds
