Problems installing Stellation plug-in in Eclipse [message #22972] |
Wed, 11 September 2002 14:05 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: dip.quinary.com
we've encountered problems while trying to install the Stellation plug-in
into Eclipse.
We have Eclipse 2.1 on win2k platform and we've successfully installed a
Stellation CM server.
We follow exactly the step-by-step tutorial for Setting up Stellation in
Eclipse (http://www.eclipse.org/technology/index.html) and then the
start following Stellation Plug-in User's Guide
(http://www.eclipse.org/technology/index.html), but unfortunately when we
click on Team -> Share Project on our project, we can't see the entry for
Stellation CM...
Do you have any idea of why this happends?
Piero
xpLayers lab
Quinary s.p.a
Milano - Italy
Re: Problems installing Stellation plug-in in Eclipse [message #23879 is a reply to message #22972] |
Fri, 13 September 2002 14:59 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Originally posted by: jim.wright.acm.org
Hi Piero,
Sorry for the delay responding; my news client was down for a day.
Could you tell me a bit more about how you installed the client?
I'm assuming you downloaded source from CVS, built the plug-ins locally,
and then launched a second instance of Eclipse (using Debug or Run).
As you probably know, if you built the Stellation CM plug-ins but did
nothing further to install them, they will not be part of your runtime
Eclipse workbench, but will only appear when you launch a Run-time
Workbench instance from within Eclipse.
Also - could you let me know *when* you downloaded the CVS source?
The codebase has been in flux recently, and the Stellation Eclipse
client code has not yet fully caught up with changes to the
Stellation Core code.
Jim
dip@quinary.com (Piero) wrote in news:alnijh$865$1@rogue.oti.com:
> plug-in into Eclipse.
> a Stellation CM server.
> in Eclipse (http://www.eclipse.org/technology/index.html) and then the
> we click on Team -> Share Project on our project, we can't see the
> entry for Stellation CM...
> Piero
> xpLayers lab
> Quinary s.p.a
> Milano - Italy
Re: Problems installing Stellation plug-in in Eclipse [message #581964 is a reply to message #22972] |
Jim Wright![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=jwright%40watson.ibm.com) Messages: 2 Registered: July 2009 |
Hi Piero,
Jim
> Piero
> xpLayers lab
> Quinary s.p.a
> Milano - Italy
FUDForum. Page generated in 0.03553 seconds
