Home » Eclipse Projects » GEF » How to create a DirectEditManager using ComboBoxCellEditor in GEF?
How to create a DirectEditManager using ComboBoxCellEditor in GEF? [message #23065] Wed, 02 October 2002 17:35 Go to next message
Hal is currently offline HalFriend
Member
Is it possible use ComboBoxCellEditor instead of TextCellEditor as the cell
editor for my Edit Manager
it works if I do this:
directEditManager = new MyEditManager ( aEditPart, TextCellEditor.class,
aCellEditorLocator);
but can I do this:
directEditManager = new MyEditManager ( aEditPart, ComboCellEditor.class,
it does not work. Is there something else I need to do?
any help is appreciated.
Re: How to create a DirectEditManager using ComboBoxCellEditor in GEF? [message #23297 is a reply to message #23065] Wed, 02 October 2002 18:36 Go to previous messageGo to next message
Originally posted by: hudsonr.us.eye-bee-em.com
"Hal" <otaconss2@hotmail.com> wrote in message
news:anf9g5$q89$1@rogue.oti.com...
cell
> but can I do this:
Can you be more descriptive? Do you not see the ComboCellEditor at all?
Re: How to create a DirectEditManager using ComboBoxCellEditor in GEF? [message #23318 is a reply to message #23297] Wed, 02 October 2002 20:05 Go to previous messageGo to next message
Member
No, i don't see anything.
When I use TextCellEditor, when I click on it, i can see a cursor on the
editpart and I can change text.
But when i switch to ComboBoxCellEditor, when i click on it, I don't see
anything.
Thanks for your help.
"Randy Hudson" <hudsonr@us.eye-bee-em.com> wrote in message
news:anfd44$se4$1@rogue.oti.com...
> > Hi,
> cell
> > but can I do this:
Re: How to create a DirectEditManager using ComboBoxCellEditor in GEF? [message #23361 is a reply to message #23318] Thu, 03 October 2002 00:01 Go to previous messageGo to next message
I don't have time to hack the Logic Editor to use a ComboCellEditor right
now.
Here is how I would debug it:
A) Is a Combo Control even being created? Breakpoint in constructor of
SWT's Combo.
B) Where is your Locator placing the Combo? Perhaps computeBounds(-1,-1)
isn't very meaningful for a combo, especially if it isn't showing the
current value. See DirectEditManager.show(), that is where the CellEditor
is positioned initially.
news:anfi99$ve3$1@rogue.oti.com...
> anything.
> > > Hi,
> > cell
> > > but can I do this:
Re: How to create a DirectEditManager using ComboBoxCellEditor in GEF? [message #23743 is a reply to message #23361] Fri, 04 October 2002 20:35 Go to previous messageGo to next message
Member
a CCombo object is creaetd.
But I got this exception afterward:
Unhandled exception caught in event loop.
Reason:
org.eclipse.swt.custom.CCombo.
but I don't know which exception is being thrown in CCombo. When I setup
Eclipse to break at java.lang.Exception, it just breaks at
ClassNotFoundException.
Any help is appreciate.
Thank you.
news:ang046$60v$1@rogue.oti.com...
> now.
> SWT's Combo.
> > anything.
> > > > Hi,
the
> > > cell
> > > > but can I do this:
all?
Re: How to create a DirectEditManager using ComboBoxCellEditor in GEF? [message #23784 is a reply to message #23743] Fri, 04 October 2002 20:43 Go to previous messageGo to next message
news:anksoj$qab$1@rogue.oti.com...
> Reason:
Look in your runtime-workspace/.metadata/.log file. The complete stacktrace
from the exception is logged there.
Re: How to create a DirectEditManager using ComboBoxCellEditor in GEF? [message #23827 is a reply to message #23784] Fri, 04 October 2002 22:50 Go to previous messageGo to next message
Member
Randy,
Thank you.
news:ankt8h$qhv$1@rogue.oti.com...
> > Reason:
stacktrace
Re: How to create a DirectEditManager using ComboBoxCellEditor in GEF? [message #196696 is a reply to message #23065] Fri, 23 September 2005 18:26 Go to previous message
Originally posted by: ccastedo.business-innovions.biz
Hi, I´m starting working with the directEditManager, I have a
TextCellEditor inside a figure, and also I have to put a ComboCellEditor
to appear a ComboBox next to this label, I couldn`t do this.
It´s possible please that someone could do this...
Previous Topic:Different EditParts selected in GraphicalViewer and SelectionAction
Next Topic:Is there a standard/common way to select the last EditPart added to a treeViewer?
Current Time: Wed Feb 05 14:08:47 GMT 2025
Powered by FUDForum. Page generated in 0.04687 seconds
