Home » Archived » Maven Integration (M2E) » Installing M2E Source & Development Environment
Installing M2E Source & Development Environment [message #23475] Tue, 24 March 2009 13:38 Go to next message
Originally posted by: jonathan.magma.ca
I am installing the source code for M2Eclipse following the instructions
in the Developers Guide -
http://docs.codehaus.org/display/M2ECLIPSE/Developer+Guide
I have successfully downloaded the source code and imported it into my
workspace. However when I use Project->Clean in the top level project
org.maven.ide.eclipse.parent to build a fresh copy, I get 11,980
compiler errors. I suspect this is due to Eclipse not respecting project
dependencies, and I believe that this is because I have either omitted
some configuration steps or that I do not understand how to use Eclipse
in a Maven environment.
What steps should I be taking to do things properly and arrive at a
clean build?
Jonathan Gossage
Re: Installing M2E Source & Development Environment [message #23516 is a reply to message #23475] Tue, 24 March 2009 16:26 Go to previous messageGo to next message
Originally posted by: igor.ifedorenko.com
Have you configured PDE target platform as explained on the wiki page?
Igor
> clean build?
> Thanks
> Jonathan Gossage
Re: Installing M2E Source & Development Environment [message #23559 is a reply to message #23516] Tue, 24 March 2009 19:24 Go to previous messageGo to next message
> Regards,
> Igor
>> clean build?
>> Thanks
>> Jonathan Gossage
Yes I have, but even if I had not I should be able to build in the host
Eclipse I would think.
Jonathan Gossage
Re: Installing M2E Source & Development Environment [message #23602 is a reply to message #23559] Tue, 24 March 2009 20:42 Go to previous messageGo to next message
m2e provides integration with ajdt, wtp, mylyn subclipse out of the box
and POM editor depends on GEF/zest/draw2d bundles. You have to have all
these in your target platform, otherwise you'll get compilation errors.
Am I missing something?
Igor
>> Regards,
>> Igor
>>> clean build?
>>> Thanks
>>> Jonathan Gossage
> Jonathan Gossage
Re: Installing M2E Source & Development Environment [message #23644 is a reply to message #23602] Tue, 24 March 2009 21:56 Go to previous messageGo to next message
> Regards,
> Igor
>>> Regards,
>>> Igor
>>>> instructions
>>>> project
>>>> clean build?
>>>> Thanks
>>>> Jonathan Gossage
>> Jonathan Gossage
I have all those packages installed on the target and my target is
properly defined. When I do a build, it seems to be building based on
the lexical order of the source packages as shown in Package Manager
even though I start the build with org.maven.ide.eclipse.parent selected.
Jonathan Gossage
Re: Installing M2E Source & Development Environment [message #23687 is a reply to message #23602] Wed, 25 March 2009 00:27 Go to previous messageGo to next message
> Regards,
> Igor
I apologize for the noise. I have been having finger problems all day.
It turns out that my target installation was corrupt and incomplete.
Rebuilding it fixed the problems.
Jonathan Gossage
>>> Regards,
>>> Igor
>>>> instructions
>>>> project
>>>> clean build?
>>>> Thanks
>>>> Jonathan Gossage
>> Jonathan Gossage
Re: Installing M2E Source & Development Environment [message #23815 is a reply to message #23687] Wed, 25 March 2009 09:49 Go to previous message
FYI, we are planning to provide automatic target platform management for
tycho projects. Exact details and timeframe are still been worked out,
so stay tuned ;-)
Igor
>> Regards,
>> Igor
> Jonathan Gossage
>>>> Regards,
>>>> Igor
>>>>> instructions
>>>>> project
>>>>> clean build?
>>>>> Thanks
>>>>> Jonathan Gossage
>>> Jonathan Gossage
Previous Topic:Project struture
Next Topic:M2Eclipse & Multiple JVMs
Current Time: Mon Oct 20 11:47:06 EDT 2025
Powered by FUDForum. Page generated in 0.06649 seconds
