Home » Language IDEs » ServerTools (WTP) » Apache Ant build.xml has no DTD or XML Schema,but I want to validate other files
Apache Ant build.xml has no DTD or XML Schema,but I want to validate other files [message #227208] Mon, 26 January 2009 06:45 Go to next message
Apache Ant build.xml files has no DTD or XML Schema, which makes it
impossible to make validation work.
Currently I get this warning:
"No grammar constraints (DTD or XML schema) detected for the
document. build.xml webcookie line 1 XML Problem"
I have looked around in the settings and I can't seem to be able to turn
this warning off. Ideally I would want to exclude this specific file from
validation, but if that is not possible disabling validation all together
would be a good idea.
So my question is: How do I exclude that file from validation? And if that
is not possible; How do I turn something off to make this warning go away?
I'm using Eclipse 3.4.1 with the latest WTP (with latest update of all
plug ins).
Re: Apache Ant build.xml has no DTD or XML Schema,but I want to validate other files [message #227229 is a reply to message #227208] Mon, 26 January 2009 14:32 Go to previous messageGo to next message
Originally posted by: wknauf_NO_._INSIDE_hg-online.de
Hi Kent,
instead of a long explanation I provide you with a link to a set of screenshots
(you have scroll down about one screen page until you see the first screenshot,
unfortunately the website is in german, but the images will hopefully help anyway):
http://www.informatik.fh-wiesbaden.de/~knauf/KomponentenArch itekturen2008/jsfunit/index.html#project
Hope this helps
Wolfgang
Kent Larsson schrieb:
Re: Apache Ant build.xml has no DTD or XML Schema,but I want to validate other files [message #227262 is a reply to message #227208] Mon, 26 January 2009 18:25 Go to previous messageGo to next message
Nick Sandonato is currently offline Nick SandonatoFriend
Kent Larsson wrote:
> from validation, but if that is not possible disabling validation all
> together would be a good idea.
> that is not possible; How do I turn something off to make this warning
> go away?
> plug ins).
You can turn off this warning for all XML documents by using the XML
Files preferences. From the Preference page, choose XML > XML Files.
Under the section "Validating files" you can change the severity in the
drop down from Warning to Ignore. Just note that this is for all XML
files, not just build.xml. But, as Wolfgang mentioned, you can just add
build.xml to the exclude filter if you would still like this warning for
other XML files.
Re: Apache Ant build.xml has no DTD or XML Schema,but I want to validate other files [message #227343 is a reply to message #227208] Tue, 27 January 2009 16:42 Go to previous message
Nitin Dahyabhai is currently offline Nitin DahyabhaiFriend
> go away?
> plug ins).
http://www.eclipse.org/webtools/releases/3.0.0/newandnotewor thy/sourceediting/xmlvalidation.png
should be what you're looking for.
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
_
Nitin Dahyabhai
Eclipse Web Tools Platform
Previous Topic:Templates don't work
Next Topic:Facet uses JRE name. The JRE name may not be available on others computers.
Current Time: Wed Feb 05 19:09:44 GMT 2025
Powered by FUDForum. Page generated in 0.04306 seconds
