Home » Eclipse Projects » Eclipse Platform » How to add Filters to Navigator view ?
How to add Filters to Navigator view ? [message #169] Thu, 17 April 2003 13:43 Go to next message
Originally posted by: ivar_vasara.cbc.ca
Hello Eclipsistas,
I'd like to be able to filter certain resources from my navigator view.
Using the navigator menu, I can select existing filters (*.class and .*
by default) but I can't find any place where I can define my own...
The help file (*) doesn't address this either, simply directing me to
select an existing filter..
* relevant help page
http://dev.eclipse.org/help21/index.jsp?topic=/org.eclipse.p latform.doc.user/tasks/tasks-48b.htm
Sincerely,
Ivar
p.s. I realize that this forum has been labeled as the discussion forum
for plugin development, but this forum's name also suggests this is the
best place for generic workbench questions such as this.. perhaps a more
clearly labeled hierachy would be better ? eg:
eclipse.platform.plugins
eclipse.platform.workbench
etc..
Re: How to add Filters to Navigator view ? [message #182 is a reply to message #169] Thu, 17 April 2003 14:06 Go to previous messageGo to next message
Originally posted by: mccull1NOSPAMPLEASE.us.ibm.com
"Ivar Vasara" <ivar_vasara@cbc.ca> wrote in message
news:b7moku$j2v$1@rogue.oti.com...
> Hello Eclipsistas,
<SNIP>
The only way to do this currently is to write a plugin that defines a new
filter. Such a plugin could be just a plugin.xml file (you do not need
code). See the docs for the appropriate extension point.
> etc..
Let's not open that can of worms again :) We'll just have to make do...
-Andrew
Re: How to add Filters to Navigator view ? [message #225 is a reply to message #182] Fri, 18 April 2003 00:28 Go to previous messageGo to next message
Originally posted by: ed.burnette.REMOVE.THIS.sas.com
The appropriate extension point in this case being
org.eclipse.ui.resourceFilters.
Ed Burnette, co-author Eclipse in Action (www.manning.com)
"Andrew McCullough" <mccull1NOSPAMPLEASE@us.ibm.com> wrote in message
news:b7mpn7$k63$1@rogue.oti.com...
Re: How to add Filters to Navigator view ? [message #243 is a reply to message #169] Fri, 18 April 2003 11:15 Go to previous messageGo to next message
Originally posted by: knut_radloff.oti.com
"Ivar Vasara" <ivar_vasara@cbc.ca> wrote in message news:b7moku$j2v$1@rogue.oti.com...
> Hello Eclipsistas,
Like Andrew writes, you can't define your own filters without writing code.
See also http://bugs.eclipse.org/bugs/show_bug.cgi?id=1970
Knut
Re: In AGR While Creating Datapool, "Link to Datapool" is not visible [message #1788247] Wed, 30 May 2018 12:26 Go to previous messageGo to next message
Re: Eclipse Chapter in Maven Book [message #1820495] Tue, 21 January 2020 21:20 Go to previous message
Previous Topic:Eclipse does not accept https certificate
Next Topic:How to get Package Explorer to indicate when a Java source files (.java) contains a deprecated class
Current Time: Sun Apr 27 08:40:29 EDT 2025
Powered by FUDForum. Page generated in 0.05788 seconds
