Re: XML not Publishing to Tomcat 6.x and 5.5 [message #224706 is a reply to message #224691] |
Thu, 04 December 2008 13:21 |
Originally posted by: mauro.molinari.cardinis.com
Ralph Bosson ha scritto:
> I have a .war project with Spring Nature mixed with Hibernate. When
> published to a Tomcat
> application server outside of Eclipse (tested on 5.5 and 6.0.18) all
> works as described. When the war is deployed to a Tomcat server running
> in Eclipse/Tomcat not all xml files are published. Any xml file in the
> WEB-INf/classes/any/and/all/subfolders is not published. If the name of
> any file that is not published has the extension xml removed it
> publishes as expected. This has gone through the bugzilla process
> (bug/256707) without success. Has anyone else seen this effect and
> successfully dealt with it. I believe any question you have has been
> asked and answered in the bug comments, for brevity I have not repeated
> the detail tests here.
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=256707
> Thanks Ralph
I've replied in the bug report. Maybe your problem is caused by bug #230050?
Mauro.
FUDForum. Page generated in 0.03093 seconds
