Re: HTML Page designer palette [message #222385 is a reply to message #221763] |
Mon, 29 September 2008 21:16 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Carsten Spieker wrote:
> Unfortunately I still have problemts with adding JSP tag libraries to the
> editor. Maybe I still did something wrong.
> I use the Jakarta Standard Tag Library (including 'core' etc.) as a test
> JSTL. It is a JAR-file containing all the tld-files in the
> META-INF folder and the Tag-Handler classes in their packages. I add the
> JAR-file to the classpath of a plugin in my RCP-application and
> also add the Tag-Handler packages to the "Exported-Packages" in the
> Runtime-Tab of manifest.mf.
> Is this the correct way? Nothing happens in the palette of the editor.
What version of the Dynamic Web Project facet is configured on your
project? You'll need at least 2.3 to access those tag libraries.
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
_
Nitin Dahyabhai
Eclipse Web Tools Platform
FUDForum. Page generated in 0.03906 seconds
