Home » Eclipse Projects » GEF » Properties sort
Properties sort [message #221215] Thu, 10 August 2006 16:00 Go to next message
Originally posted by: vinicius.ferraz.gmail.com
Hi, I wanna know how can I implement and set a properties sort!!
ty
Re: Properties sort [message #221222 is a reply to message #221215] Thu, 10 August 2006 11:18 Go to previous messageGo to next message
On Thu, 10 Aug 2006 17:00:25 -0300
you mean sorting the entries of the PropertiesView? I think the order of that
list is defined by the method
IPropertyDescriptor [] IPropertySource#getPropertyDescriptors()
that your root class of your model should implement. I would asociate a SortAlgorithm
(Strategy pattern) to each model element.
> ty
Re: Properties sort [message #221231 is a reply to message #221222] Thu, 10 August 2006 17:13 Go to previous messageGo to next message
You need to subclass PropertySheetEntry and override:
computeMergedPropertyDescriptors
"Sebastian Gurin" <sgurin@montevideo.com.uy> wrote in message
news:20060810171816.6428f068@localhost.localdomain...
> that
> SortAlgorithm
>> ty
Re: Properties sort [message #221361 is a reply to message #221215] Fri, 11 August 2006 16:21 Go to previous messageGo to next message
it is possible to group them
You can create a class to handle the group attribute of
the PropertyDescriptor.
public class TextPropertyGroupingDescriptor extends TextPropertyDescriptor
public TextPropertyGroupingDescriptor(Object id, String displayName, String category)
super(id, displayName);
setCategory(category);
Re: Properties sort [message #221379 is a reply to message #221231] Fri, 11 August 2006 16:42 Go to previous messageGo to next message
>> that
>> SortAlgorithm
>>> ty
After do this class, I need to put it in the getAdapter(Class type) to
return my class? only that?
Re: Properties sort [message #221444 is a reply to message #221231] Mon, 14 August 2006 06:42 Go to previous messageGo to next message
>> that
>> SortAlgorithm
>>> ty
Other thing..... computeMergedPropertyDescriptors It's a private method,
i can't override it...
Re: Properties sort [message #221524 is a reply to message #221361] Tue, 15 August 2006 10:37 Go to previous message
Something simple like x, y, width, height can not be sorted using groups.
"FreeGroup" <a.herz@FreeGroup.de> wrote in message
news:ebioto$80r$1@utils.eclipse.org...
> String category)
Previous Topic:Save Problem
Next Topic:How to setup the shapes example
Current Time: Thu Sep 18 02:23:14 EDT 2025
Powered by FUDForum. Page generated in 0.07366 seconds
