Home » Eclipse Projects » GEF » How to draw the Draw2D diagrams for plain multi-page editors?
How to draw the Draw2D diagrams for plain multi-page editors? [message #221033] Wed, 09 August 2006 01:14 Go to next message
Originally posted by: zouzhile.gmail.com
Hi, i am programming a multi-editor, and i want one of its pages to to
display a Draw2D diagram. Each page for the editor is a composite, so
the problem means that how to draw a Draw2D diagram within a composite.
Best Regards:)
Robin
Re: How to draw the Draw2D diagrams for plain multi-page editors? [message #221080 is a reply to message #221033] Wed, 09 August 2006 13:12 Go to previous messageGo to next message
Robin Zou 写道:
> Best Regards:)
> Robin
the case is quite similar to the XML Schema editor, there is a source
page,and there is a diagram pages that is used to display the structures
of the current schema and make modifications to it. And my case is even
simpler, I just need to display the figures according to some model objects.
cheers
Robin
Re: How to draw the Draw2D diagrams for plain multi-page editors? [message #221097 is a reply to message #221080] Wed, 09 August 2006 13:28 Go to previous messageGo to next message
Originally posted by: remove-this-pgarbacz.pgs-soft.com.remove.this
"Robin Zou" <zouzhile@gmail.com> wrote in message
news:ebcmuk$f80$1@utils.eclipse.org...
> Robin Zou д
Re: How to draw the Draw2D diagrams for plain multi-page editors? [message #221121 is a reply to message #221097] Thu, 10 August 2006 02:50 Go to previous messageGo to next message
Pawel Garbacz 写道:
>> Robin Zou 写道:
>> objects.
> Your objective is to create CTabFolder containing as many CTabItems as you
> like. One of those would show the diagram the other would show other views
> of your data. This is quite simple: create a control (particular viewer
> showing the data in certain mode) and call setControl() on CTabItem. The
> control should have as it's parent the CTabFolder.
> Regards,
> Pawel
Hi, Pawel, i am sorry that i didn't make it clear enough. The problem is
not how to make the editor "muti-page", instead, it is how to show
draw2D diagram in one of the editor page(each page is set as a top level
composite). As to Draw 2D applications, the lightweight system is
associated with a shell, and a top figure is set as its content, then
all the sub figures can be added to the top figure and make a diagram.
However, problems arise when draw a figure in the composite, no
parent/child relationship can be set. I think i must be missing
something, for example, some kind of control has to be added as a child
as the composite, and the added child control can provide the right
place to configure the lightwightSystem and draw the figures; or the
editor page used to draw the diagram should not be a composite at all.
The muti-page eidtors code is something like this:
public class SomeEditor extends MultiPageEditorPart
protected void createPages()
createPage0();
createPage1();
createPage2();
// the page 2 is used to draw the diagram, here it is associated
// with a top level composite, all contents on page 2 should be its
// children
void createPage2()
Composite composite = new Composite(getContainer(), SWT.NONE);
FillLayout layout = new FillLayout();
composite.setLayout(layout);
BindingGraphicsComposite graphicsComposite = new
BindingGraphicsComposite(composite, SWT.NONE);
int index = addPage(composite);
setPageText(index, "Graphics");
// I want to be able to draw the Draw2D digram in this composite,
// but this code doesn't work, I must have missed something
public class BindingGraphicsComposite extends Composite
public BindingGraphicsComposite(Composite parent, int style)
super(parent, style);
this.buildingDiagram(parent);
private void buildingDiagram(Composite parent)
final Label lable= new Label("Press a button!");
Shell shell= parent.getShell();
LightweightSystem lws= new LightweightSystem(shell);
Figure top= new Figure();
top.setLayoutManager(new XYLayout());
lws.setContents(top);
Clickable above= new CheckBox("I am above");
top.add(above, new Rectangle(10,10,80,20));
any idea?
Best Regards:)
Robin
Re: How to draw the Draw2D diagrams for plain multi-page editors? [message #221151 is a reply to message #221121] Thu, 10 August 2006 06:39 Go to previous messageGo to next message
news:ebe6rc$hk9$1@utils.eclipse.org...
> Pawel Garbacz д
Re: How to draw the Draw2D diagrams for plain multi-page editors? [message #221158 is a reply to message #221151] Thu, 10 August 2006 08:25 Go to previous message
Pawel Garbacz 写道:
>> Pawel Garbacz 写道:
>>> Hi,
>>>> Robin Zou 写道:
>>>> objects.
>>> you
>>> views
>>> Regards,
>>> Pawel
>> createPage0();
>> createPage1();
>> createPage2();
>> // children
>> void createPage2()
> Actually when I was using diagram viewer I was not using the
> LightweightSystem directly but wrapped with GraphicalViewer. You can create
> a GraphicalViewer inside any container you should only give the method that
> creates the viewer the right container - and it should not be a Shell but
> also can be a Composite.
> By the way I looked into the sources of LightweightSystem class and I saw
> that it does not need a Shell, just a Canvas. GraphicalViewer class will
> create such Canvas called FigureCanvas and will draw on this surface. And
> this Canvas is created as a child of any Composite. The best GraphicalViewer
> implementation for my purposes is ScrollingGraphicalViewer - I even extended
> its functionality.
> Maybe this would help.
> Regards,
> Pawel
Hi, Pawel, your suggestion works, thanks you so much for your help!
Have a very nice day!
Robin
Previous Topic:DND Source on PaletteViewer
Next Topic:Special border problem: Problems detecting when a figure goes outside the screen.
Current Time: Wed Feb 05 10:43:28 GMT 2025
Powered by FUDForum. Page generated in 0.02023 seconds
