3.0 M8: Problems view doesn't pop up [message #219505] |
Wed, 31 March 2004 22:19 |
Originally posted by: rick.cameron.decisionscrystal.com
In previous versions, if the Problems view was hidden & you saved a source
file with compile errors, the Problems view would pop open.
This doesn't happen in M8: the Problems view stays invisible. This is the
case if the Problems view has been set to Fastview, or has been closed.
Is this a bug, or is it controlled by some well-hidden option in the
Preferences dialog?
- rick
Re: 3.0 M8: Problems view doesn't pop up [message #219513 is a reply to message #219505] |
Wed, 31 March 2004 22:39 |
Originally posted by: phil.dadabeatnik.com
Yes it is an option, but not hidden. It's on the first page:
Workbench->Show problems view when build has errors or warnings
PB
"rick cameron" <rick.cameron@decisionscrystal.com> wrote in message
news:c4ffs0$bha$1@eclipse.org...
> Preferences dialog?
> Thanks
> - rick
Re: 3.0 M8: Problems view doesn't pop up [message #219539 is a reply to message #219505] |
Wed, 31 March 2004 22:49 |
False alarm (mostly) - it's the latter. There's an item on the menu in the
toolbar of the Problems view that determines whether the view opens 'on new
problems'.
Unfortunately, the view opens even if all problems have been filtered out.
In may case, I have the filter set to show only errors. The project has lots
of warnings (because I have the warning level turned really high) but no
errors.
If I save a source file after changing it, the Problems view pops up even
though there are no errors in the project - and therefore nothing visible in
the Problems list!
- rick
> Preferences dialog?
> Thanks
> - rick
FUDForum. Page generated in 0.04361 seconds
