Home » Archived » Riena » [Ridgets] Support for EMFDatabinding
[Ridgets] Support for EMFDatabinding [message #21682] Tue, 17 February 2009 14:11 Go to next message
Tom Seidel is currently offline Tom SeidelFriend
Member
Probably I'm doing something wrong, but I declare a binding as follow:
IObservableValue emfObs = EMFEditObservables.observeValue(editingDomain,
getModelObject(),
MyEMFPackage.Literals.MYOBJ__MYEATT);
myTextRidget.bindToModel(emfObs);
myTextRidget.updateFromModel();
but this does not work, The #updateFromModel is executed and the value
is rendered in the text-field, but a UI-to-Model Update does not work.
EMF has a separate DataBindingContext with different
UpdateValueStrategies. Is it possible to use a EMFDataBindingContext (I
want the use the capabilities EMF.Edit provides)? -
I didn't see any possibility to override or extend to provide my own
databinding-context.
Thx for your help
Tom
Re: [Ridgets] Support for EMFDatabinding [message #21727 is a reply to message #21682] Tue, 17 February 2009 14:26 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
If you rely on the default converters you need to use an
EMFDatabindingContext because EMFObservables report the structural
feature as the value-type.
If Riena doesn't allows you to set it you can work around by explicitly
setting an converter but that's far from ideal :-)
Tom
Tom Seidel schrieb:
> getModelObject(),
> Thx for your help
> Tom
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: [Ridgets] Support for EMFDatabinding [message #21772 is a reply to message #21727] Tue, 17 February 2009 14:30 Go to previous messageGo to next message
Member
Hi Tom,
> need to use an
that's exactly the problem. It seems to me I can not set this context.
Tom
Tom Schindl schrieb:
> Tom
> Tom Seidel schrieb:
>> Hi,
>> getModelObject(),
>> Thx for your help
>> Tom
Re: [Ridgets] Support for EMFDatabinding [message #21815 is a reply to message #21772] Tue, 17 February 2009 15:04 Go to previous messageGo to next message
Tom Seidel schrieb:
> Hi Tom,
>> need to use an
This is one of the rare cases the DB creators failed a bit because the
Databinding-Context is not the appropriate location for this. It would
be better if I one could plug-in his/her own converters.
Something like:
------------8<------------
DatabindingContext dbc = ... ;
dbc.setConverterStrategy(....);
dbc.setValidatorStrategy(....);
There's a bug with a discussion about this problem and possible solution
but this won't get fixed in time of 3.5.
Tom
Re: [Ridgets] Support for EMFDatabinding [message #21950 is a reply to message #21815] Sun, 22 February 2009 12:56 Go to previous messageGo to next message
Member
Maybe. But I'm wondering if this "failure" can't be workarounded by
Riena itself with providing some API for using my own DatabindingContext.
Any thoughts?
> Tom Seidel schrieb:
>> Hi Tom,
>>> need to use an
> Something like:
> Tom
Re: [Ridgets] Support for EMFDatabinding [message #21995 is a reply to message #21682] Tue, 24 February 2009 04:31 Go to previous message
Originally posted by: evolanakis.innoopract.com
Hi Tom,
- using your own DataBindingContext is not supported. Please file an
enhancement request so we can keep track of this.
http://www.eclipse.org/riena/bugs.php
- feel free to attach a standalone example (or projects) to that bug, so
we can experiment with your issue without spending lot of time with EMF.
- I know that other people on the newsgroup use EMF and Riena. Has this
been a problem, or how did you work around this?
Kind regards,
Elias.
Tom Seidel wrote:
> getModelObject(),
> Thx for your help
> Tom
Elias Volanakis
Innoopract, Inc.
http://www.innoopract.com
Re: [Ridgets] Support for EMFDatabinding [message #580683 is a reply to message #21682] Tue, 17 February 2009 14:26 Go to previous message
Tom
Tom Seidel schrieb:
> getModelObject(),
> Thx for your help
> Tom
Re: [Ridgets] Support for EMFDatabinding [message #580702 is a reply to message #21727] Tue, 17 February 2009 14:30 Go to previous message
Member
Hi Tom,
> need to use an
Tom
> Tom
> Tom Seidel schrieb:
>> Hi,
>> getModelObject(),
>> Thx for your help
>> Tom
Re: [Ridgets] Support for EMFDatabinding [message #580727 is a reply to message #21772] Tue, 17 February 2009 15:04 Go to previous message
Tom Seidel schrieb:
> Hi Tom,
>> need to use an
Something like:
Tom
Re: [Ridgets] Support for EMFDatabinding [message #580798 is a reply to message #21815] Sun, 22 February 2009 12:56 Go to previous message
Member
Any thoughts?
> Tom Seidel schrieb:
>> Hi Tom,
>>> need to use an
> Something like:
> Tom
Re: [Ridgets] Support for EMFDatabinding [message #580820 is a reply to message #21682] Tue, 24 February 2009 04:31 Go to previous message
Elias Volanakis is currently offline Elias VolanakisFriend
Member
Hi Tom,
Kind regards,
Elias.
Tom Seidel wrote:
> getModelObject(),
> Thx for your help
> Tom
Elias Volanakis
Innoopract, Inc.
Previous Topic:[Ridgets] Support for EMFDatabinding
Next Topic:Riena BOF at Eclipse Con 2009
Current Time: Tue Jan 14 13:06:04 GMT 2025
Powered by FUDForum. Page generated in 0.03610 seconds
