Home » Eclipse Projects » GEF » need Help for Loop connection
need Help for Loop connection [message #217928] Wed, 14 June 2006 22:14 Go to next message
No real name is currently offline No real nameFriend
I am developing a verification system using GEF, but I got trouble with the
Loop connection. Because some of the states have connections not with other
states, but with themselves.
thx and any answer would be appreciated!
Re: need Help for Loop connection [message #217962 is a reply to message #217928] Thu, 15 June 2006 12:03 Go to previous message
Spirit is currently offline SpiritFriend
Normal CreateCommand for connection between two objects will check to assure
that two ends of the connection are different, so you just jump over that
check and let you command execute to your need.
And maybe you will have to implement a new router or something.
Hope this can help you :-)
"Leon" <dai_uni_kl@hotmail.com> д
Previous Topic:How to copy IFigure?
Next Topic:Incorporating flow example into rcp app
Current Time: Wed Feb 05 14:00:44 GMT 2025
Powered by FUDForum. Page generated in 0.05058 seconds
