old bounds [message #217695] |
Mon, 12 June 2006 07:10 |
Originally posted by: g.bagga.zensar.com
hi,
is there any way to get old bounds of a figure i.e prior bounds just one
step back from the current state.
regards
gaurav v bagga
Re: old bounds [message #217712 is a reply to message #217695] |
Mon, 12 June 2006 10:44 |
Originally posted by: adam.giemza.gmx.de
save them somewhere in your model. ich you change the size of the
figure, the model should be invoked somewhere from a command to change
it's size. there you can save the old size in a field called
olderOldSize or somethink like this!
gaurav bagga schrieb:
> hi,
> one step back from the current state.
> regards gaurav v bagga
Re: old bounds [message #217721 is a reply to message #217712] |
Mon, 12 June 2006 12:01 |
hi,
thanks for replying
well i was thinking of doing smting same but i have seen when we do a
redo it gets back to previous state so there is some mechanism by which
gef takes care of previous state can we leverage that if possible....
any idea!!!!!!!!!!!!!!
regards
gaurav v bagga
Re: old bounds [message #217727 is a reply to message #217721] |
Mon, 12 June 2006 12:30 |
this is part of commands, the have to redo and undo something. but in
the command you have access to the model, so you could get your values
from there.
gaurav v bagga schrieb:
> hi,
> thanks for replying
> regards
> gaurav v bagga
Re: old bounds [message #217772 is a reply to message #217727] |
Tue, 13 June 2006 10:10 |
hi,
thanks well i have completed the job by taking care of the previous
state using commands..
regards
gaurav v bagga
FUDForum. Page generated in 0.03441 seconds
