How to build universal binaries on OSX? [message #212447] |
Sun, 23 March 2008 19:52 |
Originally posted by: jens.ja-web.de
hello,
I use eclipse cdt (5.0) to build plugins for X-Plane (shared libs). I
have CDT set up and running on WinXP, Linux and OS X 10.4 PPC.
One final piece is missing: the shared lib created on OS X seems to be
powerPC only and I need it to be cross-plattform PPC+Intel = universal
binary.
Looks like I have to specify the two platforms as target for GCC but I
cannot figure out where in the CDT project settings I have to put this
options.
(so far I used xcode on this mac to build universal but I'd rather like
use CDT to be consistent across all three platforms)
thanks
Re: How to build universal binaries on OSX? [message #216829 is a reply to message #212591] |
Fri, 30 May 2008 09:04 |
Mike Jackson wrote:
> On 2008-03-23 15:52:12 -0400, Jens Ansorg <jens@ja-web.de> said:
>> hello,
>> binary.
> I do this by adding one more piece to the puzzle: CMake.
> (www.cmake.org). CMake will generate the makefiles for CDT to use, and
> in those makefiles is the ability to create Universal binaries.
> Actually, if there is a section in eclipse to add c/c++ flags, add
> "-arch ppc -arch i386" and gcc _should_ build a universal binary for you.
> Mike
hi,
finally I got around to try this. But I get an error
Invoking: GCC C Compiler
gcc -DAPL=1 -O0 -g3 -Wall -c - fmessage-length=0 -arch ppc -arch i386
-MMD -MP -MF"SimDataSender/SimDataSender.d"
-MT"SimDataSender/SimDataSender.d" -o"SimDataSender/
SimDataSender.o" "../SimDataSender/SimDataSender.c"
gcc: -E, -S, -save-temps and -M options are not allowed with multiple
-arch flags
So the next question: how to get rid of those -Msomething flags? I see
nothing in the eclipse build configuration that relates to those flags.
(using CDT Ganymede M1 by now)
An ideas?
thank you
Jens
Re: How to build universal binaries on OSX? [message #216859 is a reply to message #216829] |
Fri, 30 May 2008 21:15 |
Mike Jackson Messages: 128 Registered: July 2009 |
On 2008-05-30 05:04:24 -0400, Jens Ansorg <jens@ja-web.de> said:
>>> hello,
>>> binary.
>> you.
>> Mike
> hi,
> -arch flags
> An ideas?
> thank you
> Jens
Nope.. I use CMake and let Eclipse use the makefiles generated from
that. I would say look deep in the compiler options flags.
mike
FUDForum. Page generated in 0.03981 seconds
