Home » Language IDEs » C / C++ IDE (CDT) » build without make?
build without make? [message #211473] Mon, 10 March 2008 03:38 Go to next message
I'm taking embedded courses in school and we are using CDT. I come from
a Java background and I find using 'make' to be a pain. Has anyone
looked at skipping make altogether to do builds. Does gcc expose a
compiler api that could be used from JNA? Or could the command line be
wrapped?
wdyt?
Cameron
Re: build without make? [message #211558 is a reply to message #211473] Mon, 10 March 2008 12:23 Go to previous messageGo to next message
> wrapped?
> wdyt?
> Cameron
Have you tried managed builds? In CDT 4.0, if you create an Executable
project, it'll build automatically without Makefiles. If are in CDT 3.x,
create a Managed Builder project.
Doug.
Re: build without make? [message #211572 is a reply to message #211558] Mon, 10 March 2008 14:50 Go to previous messageGo to next message
Yes, I'm using CDT 4 and I have tried using the Managed Builder briefly. My understanding is that it produces and runs
makefiles that it manages. Is that not correct? Does it run the compiler/linker directly?
Cameron
>> from a Java background and I find using 'make' to be a pain. Has
>> anyone looked at skipping make altogether to do builds. Does gcc
>> expose a compiler api that could be used from JNA? Or could the
>> command line be wrapped?
>> wdyt?
>> Cameron
> Cheers,
> Doug.
Re: build without make? [message #211580 is a reply to message #211572] Mon, 10 March 2008 14:51 Go to previous message
> briefly. My understanding is that it produces and runs makefiles that
> directly?
> Cameron
>>> wdyt?
>>> Cameron
>> 3.x, create a Managed Builder project.
>> Cheers,
>> Doug.
Depends on the toolchain. But either way, it is hidden from you.
DOug.
Previous Topic:Project isn’t built when makefile changes?
Next Topic:makefile for .lib
Current Time: Thu Oct 23 12:01:21 EDT 2025
Powered by FUDForum. Page generated in 0.05064 seconds
